    Fry render v1 released
    36 Posts 12 Posters 5.4k Views 12 Watching
      remus
      like it says.
      http://fryrender.com/#home/index
        remus
        Cheers for the additional info kwist, just got to wait for the real time 3D walkthroughs they were talking about now. That should be interesting 👍
        • K Offline
          kwistenbiebel
          Yes, the real time walkthrough feature is called 'Random Control 4' and will be a completely seperate software package.
          But Fryrender will be able to export to RC4.
          I am not really sure how it will work (no one really knows actually), as there seems to be a lot of secrecy around the project.
          • soloS Offline
            solo
            Impressive site, lots of eye catching images.
            Gotta make an investment soon into something like this.
            Chris, If I was to decide between Fry render and Maxwell, what advise could you give me.
            http://www.solos-art.com
            • K Offline
              kwistenbiebel
              Good catch Remus.
              Indeed, v. ONE is finally out and I must say that the Sketchup plugin has a lot of improvements concerning the workflow.
              I did quite some nagging on their forum to get some of these little things implemented (a render button, exact SU viewport match, animation support, a default place for the Fry toolbar in the SU GUI, component instances instead of groups,etc..).
              Fry is now very well suited for use in a Sketchup combo.
              Especially the 64 bit version rocks.
              The biggest difference with Maxwell is the fact that it doesn't need editing in a seperate 'Studio'.All happens smoothly within the Sketchup interface.
              The multilight feature (called 'layer blending') is also a little more advanced in my opinion as it is possible to seperate the direct sun from the sky (=you can put the sun on a separate layer and adjust its strenght on the fly).
              • soloS Offline
                solo
                Maxwell has a fast setup and well slow render, how is the setup with fry?
                The material and lighting setup?
                (maybe I should get the demo)
                • K Offline
                  kwistenbiebel
                  Personally I would go for Fry.
                  As a user you get to be closer to the developers than you are when buying Maxwell.
                  You can actually get things done and they really listen do your needs (as long as you remain polite 😄 ).
                  When comparing quality, that is difficult to answer.
                  I think they are similar and I can't really decide which is better.
                  I personally love the workflow more in Fry, definitely when seeing the latest improvements they did on the SU plugin.
                  • StinkieS Offline
                    Stinkie
                    Keep in mind that Maxwell's Studio provides you with a good way to add, say, high poly 3D trees to your scene.
                    I gotta try Fry, though. 💚
                    • K Offline
                      kwistenbiebel
                      Fry is fast at setup, slow at rendering( unbiased...you know).
                      Some people say it renders faster than Maxwell, but I haven't done a comparative test.
                      When you already have Maxwell I would stick to it, but when you have to make a new purchase I would consider Fry..
                      I don't know if the demo of version 1 is already up for download but yes, trying the demo is definitely the best way to make your choice.
                      • K Offline
                        kwistenbiebel
                        Fry does proxy/instancing from within Sketchup, which works similar to the 'dummy' approach of Skindigo.
                        It allows you to place low poly 'dummy' trees in your scene, which will be automatically replaced by the high poly 3D trees when rendering...
                          remus
                          Is there a studio in for fry as well? i got the impression form your first post that there as...
                          • K Offline
                            kwistenbiebel
                            A handy feature from within the material editor is the ability to alter the bitmap textures you assigned to the materials.
                            It has a lot of possibilities to change the appearance of the textures. (No need to get back to Photoshop to change things).
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/bitmapeditor.jpg
                            Very easy to make a bump map for instance out of the colored texture by desaturating, increasing contrast, clip whites or blacks etc...
                            It also lets you add procedural noise, color gradients etc...
                            • K Offline
                              kwistenbiebel
                              To clarify the workflow from within Sketchup I will post some screen caps.
                              This is the Fry toolbar within Sketchup:
                              http://i140.photobucket.com/albums/r3/kwistenbiebel1/frytoolbar.jpg
                              When clicking the icons of that toolbar, following windows will pop up according to which icon you click:
                              http://i140.photobucket.com/albums/r3/kwistenbiebel1/frycamera.jpg
                              http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryenvironmentsettings.jpg
                              http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryrendersettings.jpg
                              • K Offline
                                kwistenbiebel
                                The material editor:
                                How it works:
                                While having selected the Sketchup material (in the SU material browser), push the 'bucket' icon on the Fry toolbar.
                                The 'Fry material editing' window will pop and will make you setup the properties of the material:
                                http://i140.photobucket.com/albums/r3/kwistenbiebel1/mateditor-b.jpg
                                • K Offline
                                  kwistenbiebel
                                  Not in the sense of the Studio in Maxwell.
                                  But it has its own GUI (a 'mini' Studio if you like) that is launched when you push 'render' in Sketchup.
                                  It lets you adjust some things if needed (e.g view point, camera settings, material tweaks),but all the mat editing and render settings are actually already done within SU...
                                  An extended manual will be uploaded this week (according to the developers) on the Fry website.
                                    remus
                                    Cheers for the little walkthrough kwist, im tempted to give it a go now, if only i could find some time!
                                    • K Offline
                                      kwistenbiebel
                                      I just tested the new animation feature and I must admit it is a bit buggy on larger sketchup files.
                                      It seems to have trouble to save a dump file in the temp folder (crashes SU). Hopefully it will be sorted out soon.
                                      Rendering animation seems to be quite fast though.
                                      Here's a small tryout which rendered 1 minute per frame, which is actually very speedy.
                                      Just a displaced box on a surface:
                                      [flash=480,360:2autdnzb]http://www.youtube.com/v/J1MfQNjGSOw&hl=en&fs=1&ap=%2526fmt%3D18[/flash:2autdnzb]
                                      • F Offline
                                        Fletch
                                        Thanks for sharing this great review, Kwist, good work! 👍
                                        Fletch
                                        Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                        • I Offline
                                          ilay7k
                                          strange, why not to try demo? 😄
                                          anyway indigo/kerky2008/and little bit luxrender and maxwell are best
                                          holywar joke 💚
                                          • soloS Offline
                                            solo
                                            Chris, I installed Fry and unzipped the SU6 plugings and installed them into the correct folders. I am usng U6 pro and yet I do not see any icons or reference to them in plugins drop down menu.
                                            I do have the .fry export facility which opens the Fry consol.
                                            • 1 / 2
