    Bug? [semi resolved]
    3 Posts 2 Posters 1.1k Views 2 Watching
      I don't understand why that is not gluing at the end?
      The little blocks continue the race! 😲
      Group of little blocks were not "ignore" but the blocks inside yes! πŸ˜’
      Bug 2?
      But now if you rig up the group of big blocks at the double of high, they push up the little blocks! 😠
      bug.skp
      bug2.skp
        CPhillips
        Bug 2?
        Not sure what you mean. I think you didnt attach the little blocks to the slider.
          The goup of the little blocks is attached to the joint!
          If you play one time NΒ°2 and then go the start you will see that the vertical line of the joint is now on the middle of the group! So attached πŸ˜‰
          NΒ°3 with same regulate like NΒ°2(no ignore inside the groups like NΒ°1) but quasi no space between the 2 groups (The goup of the little blocks is attached to the joint! not the blocks it self : will be a painful when numerous blocks)
          And here that works but no space between groups, maybe they have not time to bouncing?
          I believe that I must build an invisible box around for avoid the explosion πŸ˜„
          bug3.skp
