    Purger
    5 Posts 2 Posters 1.7k Views 2 Watching
    • M
      Matt666
      Salut !
      Voici un petit script qui permet de purger tous les elts inutilisés, sans passer par fenêtre/Infos du modèle/Statistiques.
      Dans le menu plugins, et un icône seul.
      purger.zip
      Frenglish at its best !
      My scripts
      • W
        watkins
        Dear Matt,
        Do you plan to issue an English version? I note that you use a paint brush as the purge icon. This icon is used in other software (AutoCAD etc) to 'match properties'. I would suggest using a funnel, but this is often used as the icon for 'filter', but then I suppose purging is a form of filtering.
        Kind regards,
        Bob
        • M
          Matt666
          Hi watkins !
          It's a broom (Not on the translation 😕 Sweeper ??? 😄 ) Sweep a drawing !! Not sure a funnel be more comprehensible... I will search others icons...
          Ok !
          Tell me what you think about this icon !
          en_purge.zip
          My scripts
          • W
            watkins
            Dear Matt,
            Many thanks for the English version, and yes, I like the new Icon better. How does your script differ from TIG's PurgeAll.rb? It purges all unused components, layers, materials and styles, and one can choose which type(s) to purge from a dialog (Yes/No).
            Regards,
            Bob
            • M
              Matt666
              One step less... I didn't see it before !!!
              My scripts
