    How do i set ShadowTime ?
    3 Posts 2 Posters 745 Views 2 Watching
    • H
      hazyscl
      Hi !
      I'm currently working in a research department in a architect-engineer group in Paris, and we regularly need to export shade views of the studied buildings at three specific dates and three specific times for those dates.
      I've written this little test code for exporting shade views, but i don't seem to manage changing the shade time....
      would like some help if anyone has a hint 😉
      thanks !
      Lydia
      require 'sketchup.rb'
      def exportShadeView
      model = Sketchup.active_model
      view = model.active_view
      title = model.title
      Sketchup.active_model.shadow_info["ShadowTime"]="Thu Mar 21 14:00:00 Paris, Madrid 2002"
      if (value)
      UI.messagebox value
      else
      UI.messagebox "Failure"
      filename = title + "_21mars_10h.jpg"
      status = view.write_image filename, 5000, 4000
      if (status)
      UI.messagebox status
      else
      Add a menu to export shade views
      if( not $shadeview_loaded )
      shadeview_menu = UI.menu("File")
      shadeview_menu.add_item("Shadow Export") { exportShadeView }
      $shadeview_loaded = true
      • J
        Jim
        Hi Lydia,
        First, open the Ruby Console when writing scripts so you are able to view any error messages that are generated.
        You are trying to set the time by assigning a String. ShadowInfo["ShadowTime"] expects to be set to a Time object. Try:
        Sketchup.active_model.shadow_info["ShadowTime"] = Time.now
        or
        t = Time.local(2008, 3, 21, 14)
        Sketchup.active_model.shadow_info["ShadowTime"] = t
        Also, the variable "value" is never defined in your example, and will cause an error.
        • H
          hazyscl
          Hi Jim,
          Thanks loads for your tip!! 👍
          I'll go try it out straight away 😛
          I'll be back... 🎉
