    Problem using component spray tool
    4 Posts 3 Posters 803 Views 3 Watching
    • M
      mspisz
      I just got my hands on that nice plugin "component spray tool" I tried using it with default settings... Ok so I created a grass component andthen went into the settings clicked ok, got the circle selection out on my square plane I created before and nothing... I can make the circle big as I want and when I click left mouse button nothing happens... Whats wrong? am I missing something out?
      thanks
      • Didier BurD
        Didier Bur
        Ensure you have a layer destination set in the dialog. if not, you probably don't have latest version installed.
        Hope this helps,
        DB
        • M
          mspisz
          ok I got thanks boss πŸ˜„
          Now... I tried rendering the scene with podium but my grass is not visible.... its not there weird... what I did was to import png file and still the podium wont render it... whats wrong now? Same thing happens on vista and xp.
          • GaieusG
            That's really a render problem. Once the components are in place, the CompSpray tool's job is over. You may be more lucky with this question in the Podium Subforum under The Extensions Forum - those who can help are unlikely to chime in here.
