Smaller joints
is it possible to change the size of the joints? I made a model of something I plan on building and 1 joint is the same size as my whole model.
Cant you scale the model up and then add the joints? or jsut scale the joints?
I dont know. Can you?
Okay i probably figure it out.
You can scale the joints and they will still work. BUT if you model is that small it may cause other problems. Things that are too small don't always work as expected.
What is "too small"?
Thanks, I guess I'm safe with what I've done.
Have fun...
Dik
In the sixties there was a preoccupation with bigger joints
Register LoginAdvertisement
