    Glue blocks
    5 Posts 2 Posters 1.6k Views 2 Watching
      How makes the blocks without bouncing so that they glue at the arrival of the animation?
      How makes the solid floor "without bouncing" propriety?
      Thx by advance πŸ˜„
      Blocks.skp
        file
        Blocks.skp
          CPhillips
          Hmm. Don't think you can. Even in the real world everything bounces some. You could try cranking up the gravity to maybe make them bounce less.
            Concept πŸ˜‰
            A vertical slider is attached to each object from its base to the ground!
            Physics Joints' layer will be not visible for the final animation of course πŸ˜‰
            Your Sketchyphysics rocks! πŸ‘ β˜€
              It will be useful for make schema's animation!
              Properties can't be disabled?
              Maybe I can put invisible hollow boxes at the exact size where the bloks are falling but it's artificial tricks πŸ˜†
              And not so easy to make when you have some objects of differents forms πŸ˜‰
              Sliders maybe can make the trick but that oblige to detail the lenght of each slider's object with a precise measure from actual position to the ground for the first!
              from actual position of the second to the top of the first objet!
              etc...
              Not impossible but some hard painful
              But it's better than nothing πŸ˜„
              Found something not so difficult : sliders must have just length from each object to the ground so each object make auto blockage themselves πŸ’š
              They are bouncing at the arrival but they finish to stabilize on their vertical axes! 😍
              So if someone knows to make a little ruby for apply a slider for each object of a selection to the ground
              (or a lenght wished) that will be wonderful 😎
              Because put a slider to 3 sames objects that is fun, but for 100 differents objects that is less fun πŸ˜’
              Blocks01.skp
