    Reading mm as inches
    5 Posts 3 Posters 984 Views 3 Watching
    • chrisglasierC
      chrisglasier
      point = Geom::Point3d.new 50,0,0
      UI.messagebox(point)
      The messagebox states (1270mm,0mm,0mm)
      Window Entity, Model and Preferences are all metric.
      Can anyone help please?
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
      • Didier BurD
        Didier Bur
        Writing point = Geom::Point3d.new 50,0,0 means 50 inches on X axis
        A numeric value (for coordinates,lengths, distances, etc) is always in inches (class Length) in SketchUp. That's weird but that's the way it is.
        Just write point = Geom::Point3d.new 50.mm,0,0
        Hope this helps,
        DB
        • chrisglasierC
          chrisglasier
          Yes that's very good (given the imp/metric debacle) but now I have a problem (because I'm new to this)adding .mm to the variable in the following code:
          def self.start
          @dlg = UI::WebDialog.new("Nameset")
            @dlg.set_size 300, 180
            @dlg.set_file File.join(File.dirname(__FILE__), "openNames.html")
            @dlg.add_action_callback("find") {|d, p|
            a= p.split(",")
            subDir = a[0]+"/"+a[1]+"/"
            fileName = a[2]+".skp"
            theX = Integer(a[3])
            theY= 0
            theZ = 0
           point = Geom::Point3d.new theX,theY,theZ
            transform = Geom::Transformation.new point
            model = Sketchup.active_model
            entities = model.active_entities
            path = Sketchup.find_support_file fileName, subDir
            definitions = model.definitions
            componentdefinition = definitions.load path
            instance = entities.add_instance componentdefinition, transform
            view = model.active_view
            newview = view.zoom_extents
            @dlg.show {}
          I tried theX = Integer(a[3])+".mm" but no good.
          Would be most grateful for more sagacity!
          Chris
          • OscarLokO
            OscarLok
            Try this :-
            theX = Integer(a[3]).to_mm
            Oscar
            [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
            • chrisglasierC
              chrisglasier
              theX = Integer(a[3]).mm works.
              I'm at GMT+8, so please accept delayed thank yous.
              Chris
