    Passing coordinates javascript to callback
    3 Posts 2 Posters 419 Views 2 Watching
    • chrisglasierC Offline
      chrisglasier
      I can pass the project, subDir and file variables from this Javascript array and function
      //test components
      SUData = new Array()
      SUData.push(new Array("Sanitaryware","P_toilet",100,100,100))
      SUData.push(new Array("Sanitaryware","Sink_Counter_Triple",200,200,200))
      SUData.push(new Array("Sanitaryware","Bathtub_60x32",300,300,300))
      SUData.push(new Array("Sanitaryware","Shower_4x6",400,400,400))
      function setModel(){
      project = "NamesetComponents"
      for(a=0; a<SUData.length; a++){
      SUData[a].splice(0,0,project)
      para = SUData[a].join(",")
      window.location = 'skp:find@'+para }
      //startSetUp()
      to this callback
      @dlg.add_action_callback("find") {|d, p|
      a= p.split(",")
      subDir = a[0]+"/"+a[1]+"/"
      fileName = a[2]+".skp"
      theX = a[3]
      theY= a[4]
      theZ = a[5]
        point = Geom::Point3d.new(theX,theY,theZ)
        transform = Geom::Transformation.new point
        model = Sketchup.active_model
        entities = model.active_entities
        path = Sketchup.find_support_file fileName, subDir
        definitions = model.definitions
        componentdefinition = definitions.load path
        instance = entities.add_instance componentdefinition, transform
        but I cannot get the X, Y, Zs to work. Without them the entities settle nicely at 0,0,0.
        I am very new at this, so if there's an obvious answer I apologise but would be grateful to have it. Thanks
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        azuby
        Maybe you need to convert them (theX, ...Y, ...) to Fixnum/Integer. If you're sure they really are digits, you can use String#to_i, else you should use Integer() (i.e.: Integer(a[2])) and catch exceptions.
        azuby
          chrisglasier
          Integer(a[3] ...) works just fine. Many thanks!
