    Sketchup's API and Ruby
    5 Posts 3 Posters 1.7k Views 3 Watching
      arnouff
      my question:
      Is it possible to extract the "drawing zone" from sketchup and then, use it somewhere else using Ruby and Sketchup's API?
      Id like to insert the drawing zone in a selfmade form....... and use it code behind with Ruby. Or, remove all from the original sketchup's main screen.....menus, toolbars and the rest.
      first: is it possible ?
      if yes, how can i do ?
      thanks
      PL
      • MarianM Offline
        Marian
        First of all you should ask yourself if it's legal
          CPhillips
          I have done it. But its tricky and windows only. First I used windows messages to remove all the Sketchup UI elements leaving you with just a bare window. Then I used a C# app to grab that window and set its parent to be a panel in a form. It worked pretty well. But that was as far as I took it.
            arnouff
            mmm, legal, it's not.
            but im tricky for school.
            ... possible to fit the "drawing zone" into a webdialog ?
            ... is there any "transparency" property for a webdialog?
            i suppose the best way ("or the easy way") is a floating webdialog as a control bar
            over a naked sketchup original window.
            control bar connected to Ruby functions.
              arnouff
              To share, this is a post i found about it (by cphillips)
              Additionnal stuff:
              http://www.suwiki.org/suwiki/index.php?title=Ruby_Tutorial_-Dialog_Boxes_and_WIN32API%28Advanced%29
              the Win32API.so link below wont work
              you can get Win32API.so from there
              After you install ruby into a folder, say c:\RUBY, then Win32Api.so will be in
              c:\RUBY\lib\ruby\1.8\i386-mswin32
              the original post:
              http://groups.google.com/group/Ruby-API/browse_thread/thread/52ade11766148a57
              -The function is called "cleanSlate()".
              -It will remove all the menus and the window boarder.
              -You need to manually disable any toolbars you dont want.
              -Requires win32API.so lib(attached).
              NOTES:
              -It works by looking for a window named "Sketchup - Untitled".
              Therefore it will only work when no model is loaded. You could change
              this by editing the ruby.
              -It wont fully work at startup because the "Plugins" menu gets created
              after the cleanSlate() function is run.
              Enjoy
              Chris
              http://groups.google.com/group/sketchup-Pro-Groups/web/win32API.so
              http://groups.google.com/group/sketchup-Pro-Groups/web/cleanSlate.rb
              <code>
              require "sketchup.rb"
              require "Win32API"
              def cleanSlate()
              #setup win32 calls.
              findWindow=Win32API.new("user32.dll", "FindWindow", ['P','P'], 'N')
              sendMessage=Win32API.new("user32.dll", "SendMessage",['N','N','N','P'], 'N')
              getMenu=Win32API.new("user32.dll", "GetMenu", ['N'], 'N')
              getMenuItemCount=Win32API.new("user32.dll", "GetMenuItemCount",['N'], 'N')
              getSubMenu=Win32API.new("user32.dll", "GetSubMenu", ['N','N'], 'N')
              deleteMenu=Win32API.new("user32.dll", "DeleteMenu", ['N','N','N',],'N')
              drawMenuBar=Win32API.new("user32.dll", "DrawMenuBar", ['N'], 'N')
              setWindowLong=Win32API.new("user32.dll", "SetWindowLong",['N','N','N'], 'N')
              #find the sketchup window
              pw=findWindow.call(0,"Untitled - Sketchup")
              #remove the menu
              menu=getMenu.call(pw)
              while(getMenuItemCount.call(menu)>0)
              	deleteMenu.call(menu,0,0x400)
              	drawMenuBar.call(menu)
              #force the layout to update.
              sendMessage.call(pw,0x0047,0,"")
              #remove the window boarders
              setWindowLong.call(pw,-16,0x00800000|0x10000000|0x00080000|0x00040000)
              </code>
