    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    I want this ...
    25 Posts 9 Posters 1.2k Views 9 Watching
      remus
      That looks like good fun, a beast as well.
      As for the software, i iamgine it would be pretty simple with an unbiased render engine like maxwell or indigo, as you could jsut set each of the motherboards up as a slave and render like that.
      Not sure where you could fins 6 quad cores very cheaply though, i thought the going rate was about 100 quid πŸ˜• even assuming you got them half price your still looking at 300 quid for the CPUs alone. But then thats a render farm for you πŸ˜‰
      • I Offline
        igor
        well, im still sticking with alienware's octuple core monster with 4 terabytes of memory.
        and yes juju, it will run crysis, very very well.
        The genius switch has no "off" position
        Intelegence is natrual, it takes real effort to be ignorant
          dudekracked
          guys, ive found something more powerful called fastra
          Document Has Moved
          (www.engadget.com)
            remus
            Good find, its a pity there arent really many render engines that run on GPU power, youd be sorted otherwise!
            Not to mention that fac that you could play crysis on a cinema screen on 'very high' settings πŸ˜†
              lewiswadsworth
              I was at an IKEA today and was very tempted to buy a Helmer...
              col sporcar si trova
              • 2 / 2
