    Easy and free Render
    46 Posts 17 Posters 8.5k Views 17 Watching
      Latetzki
      Hello
      I have been looking for good rendering plug-in for Sketchup for long time now, without any good result. So, it should be easy to use and free. Is there even that kind of plug-in's?
      • StinkieS Offline
        Stinkie
        Biased: Podium (the free version has an output resolution limit)
        Unbiased: Indigo
        There's Kerkythea too (both biased and unbiased). Little harder too use.
          Tim M
          Try SU Podium http://www.suplugins.com/index.php?p=home. There is a fully functional free version that produces great results. And it works within SU. Just check their forum for some incredible renders. You are limited in the size of your exported image though. I started with the free version to check it out and ended up purchasing a license. It is well worth it.
          Tim
          @latetzki said:
          Hello
            Latetzki
            Unbiased: Indigo
            So there is no easy one? πŸ˜„ I have tried Podium but it renders way too small pics, if remember right.
            EDIT: And now it quits whole sketchup while it renders my model.
              Tim M
              Podium is easy to use but the more you get into it the better results. It’s like SU. It is easy to use but the more experienced you are with it the more you can do too. The free version is limiting as far as image size goes. I am just beginning with Podium myself but I am encouraged by what is possible. πŸ˜„
              Unbiased: Indigo
                ScottPara
                Rendering is a art form of sorts. Many people want to click a button and get a photoreal render. There is time spent in texturing, lighting, etc. no matter what program you choose. You will see some excellent renders no matter what program you choose but remember there has been many hours spent learning the in's and out's of any renderer to get those amazing results. Look for programs with:
                A good following and reputation
                the quality you are looking for with enough options to fit any render idea you may have
                Ease of use (with any program this will come in time with using the program and studying the work of others).
                Cost (obviously many do not have a Pixar budget so cost will be a deciding factor).
                If it were me I would not only look for a good render package I would also look for a program that could do modeling as well.
                Luxology (a bit biased to this one since I recently purchased it) http://www.luxology.com
                Cinema 4D http://www.maxon.net
                Both of these are fairly easy to use and are packed with features not to mention they play well with Sketchup.
                Scott
                Love the fact that some HATE my avatar.....
                • jeff hammondJ Offline
                  jeff hammond
                  Scott
                  he's on a mac.. might want to check out cheetah.. $150
                  http://www.cheetah3d.com/
                  dotdotdot
                    ScottPara
                    There are MAC version of both Modo and Cinema 4D. Also, not sure is on a MAC since he is running XP although that could be run through bootcamp.
                    Scott
                    • RichardR Offline
                      Richard
                      unfortunately scott both Modo and Cinema 4d are far from free though infact at the complete other end of the scale!
                      If you want for a really easy to use and free renderer I'd go with stinkie's suggestion and check out Indigo. Podium could be a choice too but you'll note from the gallery the quality is rather limited but good for the price. Though if you are on a mac certainly take a serious look at cheeta. I know I'd be putting some time it with that one if I wasn't on PC!
                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                        lewiswadsworth
                        Blender (with or without Yafray, a ray tracer) is a free modeler and renderer on Mac, PC, and Linux.
                        302 Found
                        (www.blender.org)
                        It is more than a little challenging to pick up, in terms of interface, although it has a fanatical userbase ready to help you. They make us look rather lukewarm about our software of choice.
                        Do a search on these forums and you will find several members using Blender as a rendering package.
                        col sporcar si trova
                          ScottPara
                          I agree neither a free but you also get a full range of modeling tools as well as excellent render options. A investment upfront will pay off in the end. Modo is by far one of the easiest modelers next to SU. Not to mention an excellent renderer. Under $1000 is far cheaper that MAX but nothing as cheap as Cheetah, BUT cheetah can not model. All personal preference and what ones budget will allow.
                          Scott
                            jeff hammond
                            Scott
                            ha, yeah.. i was looking at tim's profile instead.. my bad..
                            i know c4d and modo have mac versions.. just throwing a much cheaper option out there.. either way, none of these suggestions are really helpful to the OP's question because he wants free..
                            dotdotdot
                            • StinkieS Offline
                              Stinkie
                              Hmm, it's quite a leap from SU to modo, ease of use wise. And as a renderer, it certainly is not the easiest app for a beginner to pick up. Also, one thing I noticed hanging around the Lux forum: if you want superior quality, a render will still take quite a lot of time.
                                ScottPara
                                LOL, agreed. While there are some GREAT free products out there I can only suggest the ones that I am currently running and happy with. I would love MODO to be free but I do not see that happening anytime soon, in the distant future, or ever!
                                  ScottPara
                                  Stinkie,
                                  Ease of use is really simple. Of course it is not SU but then again it is not MAX either. After a few hours of video I was modeling quite effortlessly. Granted remdering is never a simple task but I have found Modo to be far easier than lets say Maxwell or Vray for the same results. Render times are always dependent on the machine/farm. If you are using a P4 with 128mb of Ram...come back after summer vaction....if you have 8 cores and 16gb of Ram then things move right along. The same can be said for any renderer.
                                  Scott
                                  I know you have a tendency to lean towards podium so I will not get you too fired up trying to compare apples to apples. I too own Podium and use it occasionally but I am awaiting V2.
                                  • StinkieS Offline
                                    Stinkie
                                    πŸ˜„ I'm sure you would. But not me - I'm quite the novice. Kwisten tried it too, if I recall correctly. Didn't get far either. lol. Ah, maybe in a year or so. Though I must add SU takes care of pretty much all my modeling needs.
                                    Seriously? ❓ I find the exact opposite true! How peculiar. We must have very different brains. πŸ’š
                                    I must add, I feel, that despite of the above, I find modo an attractive app - and not that expensive either for the features it packs. ❗ Lux has put together something nice.
                                    For some things I prefer Podium. For others I prefer Indigo and Maxwell. I too am waiting V2, as I find myself running into 1.5's limitations every now and again. I know a little about what to expect of V2 (you'll forgive me for not spilling the beans), and I'm quite sure it'll be a fine app. Of course, it won't replace the likes of Maxwell - but it's not intended to do that.
                                    • N Offline
                                      notareal
                                      Unbiased: Indigo
                                      Kerkythea is fairly easy and free, try it out by yourself. Just grab Getting Started - KT2008 Echo. Kerkythea.net forum is good place to get real answers πŸ˜„ Don't forget to download latest SU2KT beta!
                                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                      • RichardR Offline
                                        Richard
                                        Stinkie,
                                        I have to agree with stinkie, it really is hard to beat the shear simplicity of maxwell given the quality of the results one can expect which is certainly better at the worst end then what I have seen from the best of MODO!
                                        If you aren't worried too much about getting perfect materials maxwell really is a one click renderer, this image was rendered with maxwell as it comes straight from the box from SU with only the glass material linked all else is just staight textures painted to the SU model and it rendered in 30min on a 2.8 dual core 1gb ram! Doesn't get much easier!
                                        The beauty I find with Maxwell is the ability to save materials to a library as opposed to the material settings being stored in SU and also the multilight feature that means you only have to worry about your camera fstop setting and all else can be adjusted when rendering has finished including varying quickly between a night shot and daytime shot!
                                        Having tested a host of renderers I'd have to suggest Maxwell is by far the easiest to learn!
                                        http://img81.imageshack.us/img81/9672/watanobbipreliminary5kg7.jpg
                                        • StinkieS Offline
                                          Stinkie
                                          ... and not even about that setting. I just set both the f-stop and the shutter speed so that everything comes out in focus. If I need dof, I just add it in Photohop using a depth map. Much more practical, as far as I'm concerned. πŸ˜„
                                          (To some "unbiased" freaks, this is cheating. I say: if it works, it works.)
                                          • FrederikF Offline
                                            Frederik
                                            Very nice render, Richard..!! πŸ‘
                                            You may find it easy to use, but I will claim that I can find many who find it extremely difficult... πŸ˜‰
                                            Any way... It seem as if some of you have misunderstood the title of this thread...
                                            Maxwell is definitely not free...
                                            There's a couple of good and free renders available...
                                            Kerkythea 2008 Echo
                                            Indigo
                                            (Sorry - can't think of more..)
                                            I suggest you download them and try them out... πŸ˜‰
                                            They are both excellent render engines and the best is the one you find most comfortable to work with and can learn the intricacies the quickest... πŸ˜‰
                                            My best advice will be that you download and read the tutorials available, which will help you getting started... πŸ˜‰
                                            One final word, which I find being very wise.. ❗
                                            ...you must realize having the tools does not make one a carpenter, meaning that there is a level of artistic talent and desire needed in order to set up a scene, composition, lighting, texturing, modeling, and so forth that requires one to have a genuine interest and find much enjoyment in what one is doing in order to succeed.
                                            Hope this can help you further... πŸ˜„
                                            Cheers
                                            Kim Frederik
                                            • 1 / 3
