    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Hideedges script - Right Click Context
    4 Posts 2 Posters 691 Views 2 Watching
    • W Offline
      watkins
      Dear Azuby,
      Do you think you could modify your script so that I can access it from the right click context menu? I use your script a lot when reducing the poly-count of a model as I always have to hide edges.
      Kind regards,
      Bob
        azuby
        Hi Bob,
        it's done. I've added a submenu to the context menu. Download version 0.2 from http://errorinitus.de/
        Much fun!
        azuby
        • W Offline
          watkins
          Dear Azuby,
          Thank you for taking the time to modify your script. I will try it out tomorrow as it is getting rather late (00:24).
          Kind regards,
          Bob
          • W Offline
            watkins
            Dear Azuby,
            I have just had an opportunity to try out your script. Perfect!!!
            I like the undo hide-edge function too, and the right-click context menu is just SO HANDY.
            I use your script for cleaning up model elements. Suppose I am modelling an object with a 6-fold symmetry about the z-axis say. I model the object and then take a 1/6 slice, make it a component, and then rotate it about the z-axis. Using your Hide Edges script, I can click on the two bounding faces to hide the edges, then delete the faces before rotating. This saves a lot of time with the Eraser tool + shift, even in wire-frame mode.
            Thanks once again.
            Regards,
            Bob
