    Problems With su2stl.rb
    36 Posts 13 Posters 9.8k Views 13 Watching
    • G
      George W. Bush
      Hello Sketchup Gurus!
      I'm kind of having a problem with exporting .stl files. I've been using the most excellent su2stl.rb for several months now to export .stl files to my CAM software. Now all of a sudden (literally, since yesterday) this happens:
      1. Once I'm done drawing the part, I save my work as a .skp file, then I go to the .stl exporter.
        http://img292.imageshack.us/img292/4562/01hr8.th.jpg
      2. Then this happens.
        http://img292.imageshack.us/img292/1903/02oy6.th.jpg
      Any ideas as to why this is happening?
      Thanks a bunch!
      • I
        igor
        and since when is our moronic president a sketchup user? does he use it to design weapons to obliteraite what tiny scraps are left of the iraqi government? or to make plans to tottaly screw over the entire economy and education system?
        hopefuly, this is only your user name, and you are not the loony that is our president.
        i, however, have no idea how to help you with your converter problem. ask Solo.
        The genius switch has no "off" position
        Intelegence is natrual, it takes real effort to be ignorant
        • G
          George W. Bush
          Sketchup has the smallest learning curve so that I may be able to wrap my moronic brain around the interface. ๐Ÿ˜ข I'm new to CAD work and I've tried many other modeling programs. SketchUP works well for what I want to do with it. This is also the name I play Counter Strike under (as well as a satirical joke that I probably just screwed something up, hence me asking a question here), and since this is a place where people that do 3D work there may also be a connection with that as well (I've gotten messages from people on other forums asking me if I'm the same guy they play Counter Strike with. It's surprising where you find people on the Internet ๐Ÿ˜„ ). Does Solo normally frequent the ruby boards? I'd hate to bug him especially since this is my first thread here and apparently my name is catching animosity from many people.
          • I
            igor
            ok, you're odviously not the president because:
            A) you play counter strke
            B) you use smilies
            C) the president would have someone write his posts for him
            and dude, look around. you'll soon see that Solo (AKA Pete) is the SU equivilant of God.
            • R
              remus
              and back to the topic (sorry ๐Ÿ˜› ๐Ÿ˜ž it looks like youve got some reversed (blue) faces in your model, these could be messing up the exporter. To change them round all you need to do is right click on the offending face->reverse face.
              Other than that im not sure what it might be, i dont have a lot of experience using the su2stl plugin.
              • soloS
                solo
                Try saving the .skp as a different name, close SU then open up the model by clicking on new save. now try again.
                If you fail then upload it and i will convert it for you with Deep exploration.
                http://www.solos-art.com
                • I
                  igor
                  and while you're at it, get a better username. just guessing from the name and stuff, id say your probably a politicly pointed 12 year old trying to be funny.
                  and failing.
                  good luck with your exporter woes.
                  • jujuJ
                    juju
                    and failing.
                    What's with the h8 / personal attack?
                    • Didier BurD
                      Didier Bur
                      Dear Mister President,
                      Although me and my country didn't agree you decide alone to flatten Iraq, I suggest that you download the latest version (April 07 2008) at my site, here: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_fil_page.htm
                      I've recently updated it because of the problem you're having.
                      And please, send me a copy of your new brain rapid prototyping model ๐Ÿคฃ
                      DB
                      • I
                        igor
                        sorry, juju, im just a little more than pissed at the president right now. guess i should put this in the corner bar. all blasphemy against the US government will now be put there.
                        • G
                          George W. Bush
                          ok, I tried that but it still made my part on the right disappear and the part on the left 'discombobulate.' Thanks for helping me troubleshoot though.
                          It pains me to say that didn't work either ๐Ÿ˜ข I have uploaded the file.
                          The first time my problem happened, I did a search to see if there was an update to su2stl. That's what led me to this site. Many thanks for your update though because this problem seems to only happen on the small things I draw, the larger things work great! ๐Ÿ˜Ž
                          and failing.
                          What if it wasn't a joke? What if this was a test to see who would insult a new poster strictly on name alone, without regards to the actual content he or she posted? Would you have had the same reaction to my first post if I had named myself "Baby Puncher?" When you made your first post on this forum, did anyone say "And since when is Dr. Frankenstein's assistant a SketchUP user? Does he use it to reanimate a corpse to obliterate our lovely cobblestone town?" I'll still give you much respect though because you looked past your own prejudice of a specific text string just enough to point me in the right direction. ๐Ÿ‘ It's hard for people to do that- especially over the Internet.
                          Cheers to all
                          back1.skp
                          • soloS
                            solo
                            Here you go, I have not checked it yet. just a straight conversion.
                            back1[1].zip
                            • G
                              George W. Bush
                              Wow! It works great! Thank you so much for your help, solo; as well as linking me to Deep Exploration ๐Ÿ˜.
                              Also, it has come to my attention that I'll be banned soon for my name, so thanks again to everyone that tried to help me with my problem. Never forget errors are still errors no matter where they come from and the name of a 'whistle blower' doesn't make the error any less relevant. thanks again everyone!
                              Sincerely,
                              George Walrus Bush
                              • soloS
                                solo
                                โ“ sez who?
                                • StinkieS
                                  Stinkie
                                  "George Walrus Bush" ... An extremely silly, yes, even childish joke. I cannot help but like it!
                                  Coo coo, kachoo!
                                  • I
                                    igor
                                    hey, ive come to apologize. a friend read my posts and made me realize what a troll i was being. i had previously sworn to never be a troll, and didnt realize what i was doing.
                                    no hard feelings, right? and i did help you in the end, by redirecting you to Solo. right?
                                    • G
                                      George W. Bush
                                      @solo said:
                                      โ“ sez who?
                                      Well, it's not really my place to say, but I've been given a ultimatum to change my name or else. I don't really know what the 'or else' stands for, but I'm assuming some disciplinary action is about to happen- usually that means I'm about to get banned. Getting banned from places for having this username is pretty common so I'm kind of used to it...
                                      Coo coo, kachoo!
                                      Just think of the George Williams, Wades, Walts, and Warren Bushes of the world. They probably deal with this kind of name discrimination on a daily basis.
                                      Heh, no problem, igor. Apologies over the Internet are extremely rare, so I MUST accept it- I mean, who knows when that will ever happen again? ๐Ÿ˜Ž
                                      • K
                                        kwistenbiebel
                                        I vote for keeping your name.
                                        It's funny and no one should take offense really.
                                        Regards,
                                        Napoleon Bonaparte.
                                        • GaieusG
                                          @george w. bush said:
                                          @solo said:
                                          โ“ sez who?
                                          Well, Pete (solo) is a moderator here - he should know. But that the admin does not know? ๐Ÿ˜ฒ
                                          @kwistenbiebel said:
                                          ...Regards,
                                          Napoleon Bonaparte.
                                          And look at my avatar and username! Emperor Gaius (aka Caligula) was not much better than any present presidents! ๐Ÿ˜„
                                          • K
                                            kwistenbiebel
                                            [OT]:
                                            Oh! Pete became Moderator.
                                            Congrats my friend ๐Ÿ˜„
                                            • 1 / 2
