    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Collision is lost.
    4 Posts 3 Posters 7.8k Views 3 Watching
      broli
      Oke I'm not the type of guy who makes 3 threads in such a short notice, but this also has to be adressed ๐Ÿ˜›.
      Basiclly what i did was make a hinge part of a group and then attach another group (rod+ball) to the hinge. What this results in is non collidsing groups. I have included a video to show this...
      and the file.
      I btw use the latest sp2 beta.
      Spinny.skp
        CPhillips
        That is a "feature" of the physics engine. Any 2 objects that are joined by a joint will not collide. I changed it once so they did collide and it caused all kinds of problems. Future versions may have an option.
        • P Offline
          protective1
          Has an option been added yet to enable collisions for hinged objects?
          (Sidenote - I had trouble finding this post because I was searching the forum for "hinges" instead of "hinge".)
          • P Offline
            protective1
            I found out that there is a setting (as seen in the SketchyPhysics Inspector) for "ConnectedCollide" which is disabled by default. This setting must be checked for hinged objects to undergo full collision checking.
