    Slider controlers missing
    27 Posts 7 Posters 4.1k Views 7 Watching
    • Z Offline
      ziggystardust
      so what do you suggest mr. k?
      what versions are u using?
        Mr.K.1
        I'm not sure if Windows will allow it but try installing versions 8 or 7, I got 7 and it works... fairly well.
        But before that make sure your browser isn't blocking scripts, because I heard IE9 is locked down pretty tight by default.
        • Z Offline
          ziggystardust
          thx again mr. k, i'm sure god will remember all that help when the right time comes
          and you'll go to heaven 😄
          can you tell me how to check the scripts on ie, i've installed 8 after uninstalling 9
          but to no help, thought maybe some of my win features caused the problem, this is how they
          stand now.....
          • Z Offline
            ziggystardust
              Mr.K.1
              Well I had a quick look on google and found these:
              http://answers.microsoft.com/en-us/ie/forum/ie8-windows_xp/unable-to-enable-javascript-in-ie8/0aba6b02-5783-49ca-a27b-6636e43ed1dc
              I can't tell if this will work but it's worth a shot.
                rahdad1
                I noticed when using a hinge joint, nothing shows up in the slider window, but when using a servo joint the slider shows up and is functioning.
                  Scott Haines
                  I'm having the same issue as rahdad1. When I name the hinge joint in the Controller window (blue field), close the window and then re-open the window, I find that the name is gone. When I hit the play button there is no slider in the pop-up. I'm running Windows 7, Sketchup 8.0.4811 and Sketchyphysics 3.. Thanks for the help.
                  • 2 / 2
