    Geom::Transformation.rotation
    7 Posts 3 Posters 1.0k Views 3 Watching
      confitex architure
      Hello again,
      I'm trying to explore how to insert and rotate an external component. But I can't figure out how geom::Transformation.rotate works...
      I can't manage the rotation point... If I set inspoint at 0,0,0 and destpoint at 0,0,0 it works fine.
      but if I change inspoint and destpoint it doesn't rotate the component around it.
      So I tought I could do it in 3 steps.
      1. I insert component in 0,0,0 (transform)
      2. I rotate it (transform2)
      3. I move to another point (transform3), but then the operation redefine the 2nd step and turn back to its originel orientation.
        Any solution?
      def insertrotate
      	zaxis = Geom;;Vector3d.new(0,0,1)
      	inspoint = Geom;;Point3d.new 0.cm,0.cm,0.cm
      	destpoint = Geom;;Point3d.new 100.cm,100.cm,0.cm
      	transform = Geom;;Transformation.new inspoint
      	model = Sketchup.active_model
      	entities = model.active_entities
      	path = Sketchup.find_support_file "a_file.skp" ,"a_directory_under_sketchup_dir"
      	definitions = model.definitions
      	componentdefinition = definitions.load path
      	instance = entities.add_instance componentdefinition, transform
      	transform2 = Geom;;Transformation.rotation(inspoint,zaxis,90.degrees)
      	transform3 = Geom;;Transformation.new destpoint
      	UI.messagebox "Applying a new Transformation (in this case, a rotation)"
      	status = instance.transformation=transform2
      	UI.messagebox "Applying a new Transformation (in this case, a move)"
      	status = instance.transformation=transform3
        todd burch
        I can't look at this now, but if you don't get a solution before I do have time, I'll be happy to work it out for you.
        I'm the rotation transformation king, you know. 🀣
        Todd
          confitex architure
          Thanks Todd,
          Glad I found the Geom::Transformation.rotate's key master. β˜€
          It seems there's no other... I'll wait for your help 😲
          To all others:
          if I don't get an answer on december 24th, feel free to help me, I'm sure King Todd will not be upset.
            confitex architure
            I found it but do not really understand the reason why I must use .transform! instead of .transformation= ... (Todd?)
            So to rotate around the perfect insertion point of the component, type:
                instance.transform!(transform2)
            instead of:
            Hope this will help others.
              todd burch
              Glad you worked it out.
              I'll try to explain the difference between the two.
              instance.transformation= is used to build a new transformation only. The return value is a transformation that can be applied to an object.
              instance.transform! actually applies the transformation you pass; it doesn't just create a new definition of a transformation like the above does.
              An analogy might be English terms. instance.transformation=, is the imperative to get a noun. instance.transform! is the imperative to perform the action - the verb if you will.
              Ok, so maybe that analogy is poor and is completely incorrect in proper terms of English.... 😳
              Todd
                Jim
                Todd
                It's a pretty good analogy. I think of them as:
                **transformation=**set the transformation (absolute)
                tranform! apply the transformation (relative)
                  confitex architure
                  Not realy clear for me yet.
                  If I understand well, that means "transformation" is usefull for add_instance (f.e.) A kind of insert definition
                     transform1 = Geom;;Transformation.new inspoint
                     instance = entities.add_instance componentdefinition, transform1
                  and "transform!" to modify this instance.
                  But I'll get use to it. πŸ˜„
                  Thanks both of you for your help.
