    Only a Bathroom
    7 Posts 4 Posters 878 Views 4 Watching
    • K
      Khshahen
      Another SU model with VRAY render. C&C are welcome.
      Cheers,
      Khalid
      β€œEvery act of creation is first of all an act of destruction.”
      • R
        remus
        very nice, its got a good feel to it.
        crit: whats happeneing with the water in the bath? it looks almost like its the opening to an under sea cave or something πŸ˜› Maybe if you put a roof over your scene, so instead of reflecting the sky the water will reflect the ceiling.
        • K
          Khshahen
          Thanks Remus for the comment. You're absolutely right, the sky is not giving a realistic effect like a ceiling but I was unable to achieve a water looking surface using only a rectangular VRAY light. I will keep experimenting until I end up with something more realistic.
          Cheers
          Khalid
          • DanielD
            Daniel
            THOSE LOOK GREAT, KHALID
            My avatar is an anachronism.
            • K
              Khshahen
              Thanks Daniel
              • I
                igor
                SO... MUCH...GREEN!
                as you can probably tell, i think its just a little too monochromatic. the band of beig in the middle of the wall was a nice touch, but a little more of the other colors would be nice.
                needs a window too...
                great model, even if there is too mcuh green...
                The genius switch has no "off" position
                Intelegence is natrual, it takes real effort to be ignorant
                • K
                  Khshahen
                  @igor said:
                  SO... MUCH...GREEN!
                  your point is valid, I will add a window later on and maybe change the floor color.
