    Measuring Gradients???
    4 Posts 3 Posters 937 Views 3 Watching
    • M
      matt77
      Hi all
      Been a awhile since i posted... so hello again
      this may be completely unfeasible but thought i'd give it ago. I need to measure the gradients on some of the roads i have on a large terrain model. Or say on any slope in a model. You could do it one by one the old fashioned way. But was hoping somehow the slicer tool could be used. Would it be possible for a script to do this??
      i.e to check if the roads are feasible say at 1.20 or if not, to what extent they need to adjusted.
      Or does any body know if these can be done in any other software.
      Played around on this in the past but dont think it will work..
      http://www.compuneering.com/simuterra.php
      all the best
      Many thanks
      matt
      • P
        pav_3j
        i think that the roof ruby has a reature whereby you can select a face and you can chose to display the degree of the slope, and the ratio.
        any help?
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • R
          remus
          As mentioned, the TIG's roof ruby can do this. Im nto sure how well it wold work on more irregular surfaces like roads though.
          Heres the link: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=3470
          • M
            matt77
            Hi All
            thanks for the info...
            that may well do it,looks perfect. i've had that plug in for ome time but not noticed that option before,
            many, many thanks
            all the best
            matt
