    How to subtract Point3D.Z value with a variable
    8 Posts 5 Posters 1.0k Views 5 Watching
      bakbek
      seems simple but i can't make this thing work 😳
      this is form Robin Hills HeightTool.rb
      def onLButtonUp(flags, x, y, view) #called when left mouse button released
      txt='Height: '+@pt[2].to_s
      model=Sketchup.active_model
      e=model.entities
      t=e.add_text txt,@pt,@vec
      what i want to do is make this tool work relative to a set zero level... not the files axis zero. i get the user set level with the same method as in the drop ruby script so now i have a @@level=The user set value
      but performing
      txt='Height: '+(@pt[2]-@@level).to_s
      doesn't show the right value
      @@level.to_s alone works well but the subtraction doesn't
      what am i doing wrong here 😳
        todd burch
        What value is displayed?
        What is @@level prior to the subtract? What is its class?
        What is @pt[2] prior to the subtract? What is its class?
        What is the class after you do the subtract?
          todd burch
          As we can see from this prior reference:
          @pt is a Point3D. Therefore, @pt[2] would be the z value.
          Personally, I would have coded
          @pt.z
          but to each his own.
            AlexMozg
            I think that all is far simpler...
            txt='Height; '+(@pt[2].z - @@level.to_l).to_s
            or
            For example;
            @@level = 100.mm
            txt='Height; '+(@pt[2].z - @@level).to_s
              bakbek
              Hi Todd & Alex, thanks for your assistance.
              I've attached a screen capture for you to see what I'm trying to achieve here... it's not working yet.
              using the context menu when clicking on a surface i can assign the surface height to the @@level variable, it is suppose to be a number or length class as far as i can say. when i assign it directly to txt i get proper values... it is the math with the @pt (point3d class) that gets odd values as you can see in the image
              the proper height should have been 120cm at the note but it is 47.244094488189
              i guess i either mix up classes or units or something else i don't know about
              Sketchup Screen Capture
                a4chitect
                try converting your results to the metric system, you are probably getting sketchup internal imperial units.
                  bakbek
                  how to? this is what i can't seem to get right
                  • G Offline
                    GreyHead
                    Google says 120 centimeters = 47.2440945 inches
                    Bob
