    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Shuttle
    31 Posts 16 Posters 3.4k Views 16 Watching
    • soloS Offline
      solo
      And the last one, feeling a little spaced out.
      http://img520.imageshack.us/img520/301/solospace700jy8.jpg
      http://www.solos-art.com
      • boofredlayB Offline
        boofredlay
        That's it, I quit ๐Ÿ˜ฒ
        Great work.
          remus
          sweet renders sa ever, i especially liek the second ISS one, it looks erily real.
          • I Offline
            igor
            STOP IT!!!!!! you make me feel like a beginner!!!
            The genius switch has no "off" position
            Intelegence is natrual, it takes real effort to be ignorant
              dolphus
              Fantastic, realy good work, could i humbly ask how you do the backround? ๐Ÿ˜
              • soloS Offline
                solo
                Thanks y'all.
                Dolphus, the second image on the first page is incorporated into the render by means of a plane (so it's rendered)
                The first and last render on this page was done using 2 omni's only with a black background, the completed render was exported as a .png hence the background was eliminated and overlaid on an image. The second one is a straight render with multi-light omni's (stars selected in atmosphere setup).
                • StinkieS Offline
                  Stinkie
                  When I grow up, I'd like to be able to model like this.
                  Well done. Quite impressive.
                    dolphus
                    Thank you but to quote stinkie i will have to do some growing up, i have only just reached the stage where i can produce a fairly good looking airplane or space ship rendering is somthing i shall have to start learning yuor work is inspiring keep it up
                    cheers ๐Ÿ˜
                    • marked001M Offline
                      marked001
                      wow! these are incredible...i cant believe the patience you must have.. (besides, the obvious 'skill', of course)... cant stop looking at all the litle details...
                      http://www.revision21vis.com
                      instagram: revi21on
                      • DanielD Offline
                        Daniel
                        As always Pete, topnotch. I'm running out of accolades for you.
                        My avatar is an anachronism.
                          lapx
                          What do you mean in between projects ๐Ÿ˜ฎ Your so fast they can't keep up with.
                          These are excellent works. Congratulations! Personally I think you have outgrown this board. Your are an inspiration to all here so don't leave ๐Ÿ˜„
                          • 2 / 2
