    Shuttle
    31 Posts 16 Posters 5.3k Views 16 Watching
    • boofredlayB
      boofredlay
      That's it, I quit ๐Ÿ˜ฒ
      Great work.
        remus
        sweet renders sa ever, i especially liek the second ISS one, it looks erily real.
        • I
          igor
          STOP IT!!!!!! you make me feel like a beginner!!!
          The genius switch has no "off" position
          Intelegence is natrual, it takes real effort to be ignorant
            dolphus
            Fantastic, realy good work, could i humbly ask how you do the backround? ๐Ÿ˜
            • soloS
              Thanks y'all.
              Dolphus, the second image on the first page is incorporated into the render by means of a plane (so it's rendered)
              The first and last render on this page was done using 2 omni's only with a black background, the completed render was exported as a .png hence the background was eliminated and overlaid on an image. The second one is a straight render with multi-light omni's (stars selected in atmosphere setup).
              • StinkieS
                Stinkie
                When I grow up, I'd like to be able to model like this.
                Well done. Quite impressive.
                  dolphus
                  Thank you but to quote stinkie i will have to do some growing up, i have only just reached the stage where i can produce a fairly good looking airplane or space ship rendering is somthing i shall have to start learning yuor work is inspiring keep it up
                  cheers ๐Ÿ˜
                  • marked001M
                    marked001
                    wow! these are incredible...i cant believe the patience you must have.. (besides, the obvious 'skill', of course)... cant stop looking at all the litle details...
                    http://www.revision21vis.com
                    instagram: revi21on
                    • DanielD
                      Daniel
                      As always Pete, topnotch. I'm running out of accolades for you.
                      My avatar is an anachronism.
                      • L
                        lapx
                        What do you mean in between projects ๐Ÿ˜ฎ Your so fast they can't keep up with.
                        These are excellent works. Congratulations! Personally I think you have outgrown this board. Your are an inspiration to all here so don't leave ๐Ÿ˜„
                        • 2 / 2
