    Quick doors
    24 Posts 13 Posters 8.5k Views 13 Watching
    • E
      ericschimel
      Its interesting that you are having that error, it works fine on my end... (On multiple computers)
      If you wouldn't mind, could you walk me through how you got the error?
      You said that you were trying to flip the door to get it to hinge the other way....
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        Eric, when I downloaded it via IE, it would allow me to resize and change the panel and so on. Then I flipped it along the green axis to hinge the door on the right instead of the left. when I tried resizing in either direction, the component flipped around tto put the hinge on the left again. This didin't happen when I searched in the components Browser. Then everything seemed to work fine. Curiously, I also got some additional adjustment options, too.
        • E
          ericschimel
          Yes, downloading it through IE, or another browser with out importing it would have caused those issues. It is meant to be used from Sketchup's component browser, or just imported.
          -Eric
          Custom Models
          • E
            ericschimel
            Hey guys, just wanted to post this link....
            404 Not Found
            (www.sketchthis.net)
            Its a video tutorial I did to go along with that Dynamic Door...
            Check it out, it will explain all of its features....
            -Eric
            Custom Models
            • 2 / 2
