    Animation experiments
    34 Posts 9 Posters 3.9k Views 9 Watching
    • K Offline
      kwistenbiebel
      Hi all,
      I will be using this thread for my animation experiments:
      Some Breuer Wassily chairs (Indigo Render):
      http://www.youtube.com/watch?v=U-hZON6peOE&feature=related
      [flash=425,355:3pgw4di0]http://www.youtube.com/v/U-hZON6peOE&hl=en[/flash:3pgw4di0]
      Tripod animation (Indigo Render):
      [flash=540,438:3pgw4di0]http://www.youtube.com/v/pAxdSfJ8JHo&hl=en&fmt=18[/flash:3pgw4di0]
      House animation (Indigo Render):
      http://www.youtube.com/watch?v=Bs8Yvz90VKg&feature=related
      [flash=540,438:3pgw4di0]http://www.youtube.com/v/Bs8Yvz90VKg&hl=en[/flash:3pgw4di0]
      • soloS Offline
        solo
        Those are great Chris, whats the process and render times?
        Can you do a staionary animation with only sun movements, hence shadows only move?
        http://www.solos-art.com
        • K Offline
          kwistenbiebel
          Thank you Pete.
          To render an animation using Skindigo, you set up the animation the same way as a plain SU animation, meaning you make some 'scenes' ('pages' in SU5) and the in between frames will be generated automatically. After setting the render settings, a batch.exe will be generated.
          Double clicking that file will start the rendering of all frames and those will be saved as .png image files which you can import in the free 'windows movie maker' to make a .avi or .wmv.
          For these animations I set the render time to 1 minute for each frame (in reality total render time per frame was 1,5 minutes because of precalculation phase).
          I used a framerate of 10 frames/second. This means a render time of 10 X 1.5 minutes= 15 minutes per second of film.
          Thus, for a 30 second movie, the render time is : 7.5 hours.
          A stationary movie with just the sun rotating is possible yes...I'll try that later on 😉
          • K Offline
            kwistenbiebel
            A QUICK GUIDE TO SAVE THE BATCH.EXE FILE
            Actually, rendering animations is a hidden feature.
            To use it, go to the render settings screen of Skindigo ---> 'options' tab.
            Double click on the words 'output options'.
            A window will pop up that lets you save the batch.exe.
            It will ask you which framerate you want.
            I chose 10 frames per second, but for a really smooth animation consider 25 fps (if you have a render farm 😉)
            Whaat inserted this 'easter egg' in his last Skindigo version.
            Funny guy 😄....but very talented.
            HOW TO SETUP RENDER TIME PER FRAME
            Easy: go to 'render settings panel' ---> 'Advanced' Tab.
            Set the time you want each frame to be rendered at 'Halt'.
            For instance 60 seconds.
              remus
              Now if you could save s sketchy physics animation as a series of scenes...
              Good stuff kwist, ive jsut started a really quick animation of my own going. I'll never have a spare rendering moment left now!
                Cool 😄
                Some frenchies will say : "Lelouch Style"
                (a specialist of the moving camera 😄
                For the fun an old task 😉
                (here the camera is fixed 😆
                • FrederikF Offline
                  Frederik
                  Looks much better than your first attempt, Kwist... 😉
                  In particular I enjoy the camera path and angles...!! Very stylish..! 👍
                  Cheers
                  Kim Frederik
                  • soloS Offline
                    solo
                    Used straight SU model quick animation 15fps 11 minutes to render sequence as .gif in Vue.
                    http://img528.imageshack.us/img528/8769/neobk4.gif
                    • K Offline
                      kwistenbiebel
                      11 minutes 😮 😮 ...
                      That puts things in perspective 😆
                      I was already happy to have a video done in 5 or 6 hours ...and it is noisy as hell 😄
                      Lots of fun though.
                      Solo,
                      What about a full scene (yep, vegetation included) rendered in Vue?
                      That would be interesting to compare.....
                      • soloS Offline
                        solo
                        What size output?
                        I will set one up tomorrow (got two renders running at moment).
                        I will add vegetation, mountains, moving water, and moving physical sky(clouds and sun going from day to night) which should complicate things enough.
                        • soloS Offline
                          solo
                          Did a quick one with Vue 6 Xstream.
                          Procedural terrain with vegetation instancing, 15 fps, 91 frames, 430x320, on Imac g5 intel, 21 minutes.
                          [flash=423,320:952z38d2]http://www.youtube.com/v/SlDe934bj8A[/flash:952z38d2]
                          • W Offline
                            Whaat
                            hey biebel,
                            I love your tests. The house one is my favorite so far. short but very sweet. 👍 I need to do some more animation experiments myself.
                            • soloS Offline
                              solo
                              Did a quick one this morning, using a procedural terrain with water. The animation is just a camera fly-over.Vue xstream at final setting, 180 frames, 15fps, 500x420, 12 seconds, on a G5 imac, 1hour 21 mins.
                              Too bad about the youtube quality as original is crisp
                              [flash=500,420:20fif7ie]http://www.youtube.com/v/QhzYURSjGbY[/flash:20fif7ie]
                              a terrain of this size would be a tough customer in SU to navigate.
                                remus
                                Wow, good stuff pete. Render times are a lot more reasonable than indigo as well. How aobut some more close up stuff? like flythrough in a rain forest?
                                • soloS Offline
                                  solo
                                  Thanks.
                                  I need to wait for my quads to be free before trying more complexed models (use all cores).
                                  here is another done on a dual core G5 Imac.
                                  This time I used a Phillipe Bouyer scene, inserted a SU 3D SCF Model. Notice the sun rise and the wind effects on the trees, as well as the camera is effected by wind as it tracks the sun.
                                  15fps,121 frames total 8 seconds, 640x400, Final settings, 42 minutes.
                                  [flash=600,420:1hjmvq6k]http://www.youtube.com/v/-SqjW7NX8BQ[/flash:1hjmvq6k]
                                    bubbalove
                                    These videos are great! Wonderful inspiration for the newbies out there that have yet to master the video aspects of rendering! Awesome job Kwist and Pete!
                                    "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                    • soloS Offline
                                      solo
                                      This one took 67 minutes to render, has been looped once, The sky changes, snow falls, leaves disapear, leaves and grass change color, new trees grow, camera on circular rotation, SU built logo is stationary. based on Phillipe Bouyer's tutorial.
                                      [flash=400,300:1w010gxj]http://www.youtube.com/v/3qiarXzehDA[/flash:1w010gxj]
                                      • soloS Offline
                                        solo
                                        It was just a matter of time until you started playing with your balls. 💚
                                        I have one that I had to rerender as I got an ominous reflection (looks like the virgin Mary 😮 ) I will finish the one I am on right now and post it, I will also see if I can get a frame freeze shot of the reflection....just wierd.
                                        • soloS Offline
                                          solo
                                          This is the animation, done with Vue, 10 seconds, 150 frames. 600x400, done with quad core, 27 minutes.
                                          [flash=600,400:258qsjht]http://www.youtube.com/v/YwLoUeSYz5s[/flash:258qsjht]
                                          However from frame 97 to 101 appears a strange reflection on the glass (from one of the legs) that looks almost like something one can sell on Ebay to a religious nutcase for a fortune.
                                          http://img386.imageshack.us/img386/4583/frame99098rg8.jpg
                                            Cool try!
                                            Maybe this can interest you
                                            Look this one 😲
                                            Many possibilities: Donwnload, video,Hi RES, Youtube!
                                            the crazzy of this thing is the size : 179 kb ! for PC
                                            And if you want make hallucinate one : Theprodukkt...will make you happy!
                                            it's free 😉
                                            all demos are there
                                            http://www.pouet.net/screenshots/30244.jpg
                                            • 2 / 2
