    Bantam3D
    6 Posts 4 Posters 5.3k Views 4 Watching
      remus
      Just thought i should post this here so it doesn't get lost to the sands of time.
      Thanks to Bob Janes for posting the original file.
      The primary use of Bantam3D Grass is to rapidly create 3-dimensional ground covers, such as grass, leaves, and rocks. If you have downloaded and installed Grass, you can create a lawn instantly. copied form the help file.
      Sample
      http://farm3.static.flickr.com/2342/2368397807_48c8009101.jpg?v=0
      Edit: just added a quick description as requested.
      Edit 2:did a quick test render. Podium, about 9 mins. 800x600 using SU sun.
      Bantam3DGrass_7.zip
      Bantam3DGrass_7_help.zip
      • soloS Offline
        solo
        Can you give us some details as to what this freeware is about?
        http://www.solos-art.com
        • G Offline
          GreyHead
          I've put the help files up here.
          Bob
            remus
            Just a little warning to everyone, this grass is very poly intensive. The patch above was 16,000 polys so beware, you wont be able to navigate your modle if you have much of this stuff in there.
            Also, the .obj files it exports wont go into SU, youll need a program to convert them. Converting to .dxf worked well for me.
            Have fun making grass 👍
            • BurkhardB Offline
              Burkhard
              there's an obj exporter for sketchup (http://www.scriptspot.com ? )anywhere in the web.
              [http://www.ia-plus.de(http://www.ia-plus.de)]
                remus
                Do you mean the plugin by jim? if so it can be found here
