    Wintopo - Raster to Vector converter
    6 Posts 3 Posters 5.8k Views 3 Watching
    • L
      linea
      Wintopo is great for converting raster to vector or hand drawn scrawl to nice neat dxf. The free version is very good, I'm using it today to sort out a load of scanned drawings from a client. The key is to set the tolerance in the vector extraction options, I use a tolerance of about 20 - 50 pixels depending on the amount of scrawl. It's really easy to use.
      http://www.wintopo.com/
      • GaieusG
        Yeah, I have also used it though my experiences are mixed.
        • L
          linea
          Works fine if you set the tolerance.
          • GaieusG
            May try again, thanks for the tip!
            • P
              PeterCharles
              However good they are "you can't make a silk purse out of a sows ear" and most of the drawings where we could use it are real sows ears!!
              • L
                linea
                Peter,
                It's just a way to transfer stuff from raster to vector. It's always going to involve some clean-up. If the original drawing isn't even to scale though it's probably useless.
                I'm drawing up parts of a large steel sculpture, all originally drawn accurately to scale. Vectorising the drawings is relatively effortless and accurate enough for the contractor.
