    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Vespa revisited...
    7 Posts 6 Posters 773 Views 6 Watching
      Ross Macintosh
      I woke up early this morning and couldn't sleep. So I decided to play with digital watercolour techniques and revisited the Vespa model I had played with in the past. It The vespa was modelled by Allister and is available at FormFonts.
      Regards, Ross
      by Ross Macintosh, all rights reserved
      • H Offline
        huyvuvn
        did you use piranesi or photoshop ?
        happiness on the way, not in the destination.
        • soloS Offline
          solo
          Check bottom of image, Xara Xtreme pro.
          http://www.solos-art.com
          • F Offline
            fbartels
            Ross,
            Beautiful image. Sometimes less is more.
            Fred
              tomsdesk
              Very nice, Ross.
              2.5D Trees & Shrubs!
                Ross Macintosh
                Thanks guys. Yes it was done using Xara Xtreme Pro. For those who don't know it is vector illustration software - similar to Illustrator or Coreldraw. In it I do use photoshop compatible filters. The biggest difference from photoshop is that in Xara I have no 'brushes' - everything is done without their benefit. I find Xara much-much more intuitive than photoshop.
                Regards, Ross
                • FrederikF Offline
                  Frederik
                  πŸ˜„Looks great, Ross... πŸ˜„
                  (but I already knew that your digital watercolors are fantastic... πŸ˜‰ )
                  And with the low exchange rate, Xara Xtreme Pro is actually really cheap... 😲 πŸ˜„
                  Cheers
                  Kim Frederik
