    Draft of OAN Challenge - Kenya
    6 Posts 3 Posters 886 Views 3 Watching
    • F Offline
      fbartels
      I've been able to spend some time the past two days working on my submission for this challenge. It's going fairly well so I thought I'd share my progress to date. A few notes of explanation. The white posts would be PVC pipe filled with concrete. The corrugated panels are just that... transparent plastic for light and air and steel for privacy, light control, and structural support. I came up with what I think is a very inexpensive solution for windows which I'll share in another post. Please feel free to ask questions, state concerns, etc.. πŸ˜„
      This first image is pre "windows".
      http://dws.editme.com/files/JanFeb2008/draft 3.jpg
      Windows added.
      http://dws.editme.com/files/JanFeb2008/draft 3-2.jpg
      Floor plan. Includes computer lab, Internet cafe, library, radio broadcasting room, bathrooms, reception, and some office space.
      http://dws.editme.com/files/JanFeb2008/floor plan.jpg
      I've attached the file for anyone interested in taking a closer look.
      Fred
      draft 3.skp
        remus
        looking as good as ever fred. I like the design a lot.
        • W Offline
          Walter S. Arnold
          Will the PVC pipes filled with concrete support the weight? It seems to me like they'll be good in compression, but have insufficient lateral strength. (wind loads could be a problem)
          • F Offline
            fbartels
            Remus, Thanks as always for the positive feedback. Much appreciated.
            Walter, Thanks for sharing your concerns about the PVC pipes. Do you think it would make a difference if the poles (at least some of them) had rebar in them, and the rebar was tied into the foundation? It would be easy to set up the rebar, then slide the pole over it, then pour the concrete. It would also be very easy to place bolts in the PVC pipe before the pour, and then later attach various structural supports to the bolts, creating a very solid framework.
            Cut away of a PVC support pipe.
            http://dws.editme.com/files/JanFeb2008/pole cut away.jpg
            This image shows a support beam that would be bolted at both ends to PVC/concrete posts.
            http://dws.editme.com/files/JanFeb2008/beam.jpg
            Fred
            • F Offline
              fbartels
              Some additional images. I'll do some final polishing over the next few days and then submit it.
              http://dws.editme.com/files/JanFeb2008/draft 4 library end.jpg
              http://dws.editme.com/files/JanFeb2008/draft 4 lab end.jpg
              http://dws.editme.com/files/JanFeb2008/draft 4 front side.jpg
              • F Offline
                fbartels
                More on the sliding corrigated panel "windows." I put windows in quotation marks to indicate that these are very untraditional windows.
                The first image shows all the non-moving pieces. These would all be attached to side panels which are not shown. The box has screening on the outside and slats for safety.
                http://dws.editme.com/files/JanFeb2008/corrugated sheet tests 1.jpg
                The second image includes the piece of corrugated panel that would slide up and down and be held in place by fitting into groves on the side panels.
                http://dws.editme.com/files/JanFeb2008/corrugated sheet tests 2.jpg
                To make all of this crystal clear there is a movie here that shows the window in action.
                Finally, I've attached the SketchUp file so you can test it yourself. πŸ˜„
                Fred
                corrugated sheet test.skp
