    Bamboo Roof Structure for Open Architecture Challenge
    24 Posts 7 Posters 3.0k Views 7 Watching
    • F Offline
      fbartels
      Completed the 4" diameter tube sections triangle this evening. Used only one 10' tube. Sections are 2" high. I think it would be worth exploring 6" diameter tubes if they are available. This weekend I'll work on injecting foam into the interstices. I'm quite curious how stable the honeycomb will be with hardened foam between the cylinders. Stay tuned.
      http://dws.editme.com/files/JanFeb2008/4 vs 2 complete.jpg
      http://dws.editme.com/files/JanFeb2008/4 in context.jpg
        Do you know"La fievre d'Urbicande" (Urbicande fever) πŸ˜‰
        Try this site about Urbicande by Schuiten & Peters
        (there is an Introduction in English middle of the page then click red triangles to the end for understand the proliferation πŸ˜„
        Seems you are the brother of Eugene Robick πŸ˜„
        little movie about Urbicande City
        • F Offline
          fbartels
          Pilou,
          Thanks for sharing the links. The Urbicande City movie is amazing. What an imagination... and what talent to make it come alive.
          Fred
          • F Offline
            fbartels
            Latest developments...
            I injected the foam yesterday evening and the results are good but not great. The essential problem is that the cured foam is not dense enough and compresses under pressure, which in turn allows the whole structure to deflect heavily. The good news is that the honeycomb structure is quite strong even given this. I layed a 1/16" plastic sheet on top of the honeycomb and inched my (210 lbs) way out to the center of the triangle (see image below) and although the surface deflected it held up and recovered nicely after I stepped off.
            The foam, in addition to being structurally inadequate, is very hard to control. I'm looking for alternative materials to use in the interstices between the PVC sections. I'm leaning towards trying epoxy next but am open to other suggestions. An ideal material would be inexpensive, easy to apply, and cure really hard.
            BTW, I also learned not to over tighten the wire ties before injecting the foam as it makes it very hard to form the honeycomb into curves.
            http://dws.editme.com/files/JanFeb2008/deftest1.jpg
            http://dws.editme.com/files/JanFeb2008/deftest2.jpg
            http://dws.editme.com/files/JanFeb2008/foam closeup.jpg
            • 2 / 2
