    Text position problem
    23 Posts 5 Posters 3.6k Views 5 Watching
      Jorgensen
      And a other problem:
      The array $areaObjects, is not saved inside the file - so next time it is loaded - one have to manuel delete all the textobjects and add newones -
      Is there a smart workaround here ?
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        Jorgensen
        It seems that I can use
        model = Sketchup.active_model
        data = model.get_attribute "TM_area", "textObjects", "default"
        and
        value = model.set_attribute "TM_area", "textObjects", objects
        • daikuD Offline
          daiku
          J:
          You are deleting entities from the active entities list while you are iterating over the same list. In other words, you are scrambling the list whilst travesing it. Don't do that. Collect all your enities into a seperate list. Then interate through that list and delete them. CB.
          Clark Bremer
          http://www.northernlightstimberframing.com
          • 2 / 2
