    Controller problems
    2 Posts 2 Posters 1.3k Views 2 Watching
      RayL
      I'm having a slight problem with the use of a controller. I am using a wired X-Box 360 controller and seem to be missing one of the input commands. Here's the set-up:
      Action joyLX and joyLY are associated with the left joystick as they should, but joyRY seems to be associated with the two top analog triggers. I seem to be missing joyRX, as the right joystick has no function.
      http://img507.imageshack.us/img507/5343/xboxcontrollertk1.jpg
      I know this version is still in it's beta stage, so if no fix is available I completely understand. Or it could just be something obvious that I may be overlooking.
        CPhillips
        Yeah, the 360 controller is a bit different from most. I am going to make a configuration utility for the next version.
        Chris
