    WIP - Church Interior
    6 Posts 3 Posters 782 Views 3 Watching
      bubbalove
      I am doing a church in Sanford, NC. I'm going to post a quick render I did and I was wondering if someone here could maybe help me. I'm having problems with the aqua carpet showing too much on the ceiling. I haven't changed any of the material values from sketchup, I figured someone here may have seen this before or knows of a quick fix. Oh, I am using kerkythea. Thanks!
      David Love
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • jenujacobJ Offline
        jenujacob
        are u referring to the big bright round spots over ur chandeliers??
        did u use point lights to render this?
        i think it would be best if u could put rectangular emitters in the bulb holders...
        using point lights
        using rectngular emitters
          bubbalove
          Well yea, that too... but my main concern is the carpet is showing up way too much on the ceiling.
            jenujacob
            oh ok..
            i am not quite sure bout that... maybe if u could try rendering with a higher preset it might go away...
            usually this happens when the material is incorrect.. but u say that u havent done any modification to the materials in KT rite?
            • FletchF Offline
              Fletch
              Hi Bubba,
              Is your floor material following the correct physical laws? I mean, when you add up the numbers for ambient and diffuse, etc. they do not equal more than "1.0", correct?
              If you would like, as I've done many times, I can d/l and try to see if I can spot the prob.
              I will pm you my email info if you like
              Fletch
              3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                bubbalove
                Fletch, I don't mind sending you the model or the xml file. I didn't change any of the carpet settings when I rendered this one. I thought if I didn't change it, it would just be flat and not do what it continues to do. Let me know how you want me to send it to you. Thanks a lot!
                Here is another I let render last night Fletch.
