    Team SU, Please help....
    25 Posts 8 Posters 3.2k Views 8 Watching
      tomsdesk
      BTW...what "extras" does SU install if the web is available to it when installed?
      2.5D Trees & Shrubs!
        tomsdesk
        Update
        Heard from SU tech support a couple of minutes ago, so here's the email exchange in case it helps: Scott (PRSS if you're reading this thread) and/or anybody else that might have an idea triggered by it:
        %(#0080BF)[> Hi Tom,
        Thank you for your reply. We apologize for the delayed response. Since
        disabling hardware acceleration stopped the sky and shadows from flashing
        black, we can conclude that there's a conflict with the graphics card
        driver or the card itself. You may consider updating the drivers for the
        video card:
        Error 404 (Not Found)!!1
        (sketchup.google.com)
        We investigated further on our end, and we didn't locate any fixes that we
        released that correct incompatibilities with Intellipoint software.
        However, regarding your hardware acceleration settings, there may be
        another issue with the NVIDIA settings that may resolve the issue:
        1. Right-click on the Desktop and choose "Properties."
        2. Click the "Settings" tab.
        3. Click the "Quadro FX1700" tab.
        4. Click "Start the NVIDIA Control Panel."
        5. Click "3D Settings."
        6. Click "Manage 3D settings."
        7. Please make sure that "Antialiasing - Mode" is set to
          Application-controlled.
        8. Restart the computer.
        9. Open SketchUp, and click "Window" > "Preferences" > "OpenGL."
        10. Choose a capability that has a "0x" antialias setting.
        Thanks for your ongoing assistance.
        Regards,
        The Google Team]
        %(#800080)[Hey Goggle Team...and thanks:
        I have had the latest nvidia drivers from day one.
        I was using the "Autocad" preset with Vertical Sync set to "Force Off"...so
        went back to the base settings (application controls all including
        antialiasing) per your instructions: solid black turned to middle
        gray...but same issue symptoms remained. Turned vertical sync back to
        "force off" (really helps reaction time and speed on highpoly models) and
        black returned.
        Turned on the ground in both cases above and issue stopped...? Isn't this
        wierd behavior? A wierd "fix"...?
        For my own piece of mind (knowing the intellipoint software caused some
        other problems as well and most likely still lurks in the shadows) I am
        going ahead with the reformat and reinstall. I will let you know the status
        of this issue when I get the machine back. I would also like your input on
        the best nvidia settings for SU so I can set up my own profile and move
        ahead with confidence, thanks.
        Best, Tom.]
          tomsdesk
          Subsequent email from Google:
          %(#0040FF)[Hi Tom,
          There are two more settings in the NVIDIA control panel that we suggest
          checking. In the same "Manage 3D Settings" window, please ensure that
          "Antialiaing - Gamma correction" is set to "On," and "Anisotropic
          filtering" is set to "Application-controlled."
          Regards,
          The Google Team]
            Jackson
            Tom,
            Sorry if someone else suggested this already, but did you manually delete the Intellipoint key from the registry (run: regedit) after uninstalling? I've found more and more often that registry keys are left behind after supposedly uninstalling progs causing all sorts of problems. 😑 😑 😑
            Disclaimer: Of course, messing around with the registry always carries risks!
            Jackson
            • bazB Offline
              baz
              I too have been plagued by the black screen just recently.
              Downloaded new drivers and followed all the advice from google as above to no avail.
              Then scotts post reminded me that Id installed a new m/soft mouse months ago.
              The task manager showed that ipoint loaded at start up, I've disabled it and http://www.sketchucation.com/forums/scf/posting.php?mode=reply&f=72&t=5418#
              😍voila!
              No change to mouse behaviour either.
              Thanks, and thank god for the forum.
              baz
              • 2 / 2
