    External render
    5 Posts 3 Posters 555 Views 3 Watching
      chrischeal69
      hi guys
      this is one of my first external renders in kerkythea and photoshop. quite happy but has anyone any ideas of how i could improve the image. i cant seem to insert globals from the drop down menu as no box appears when i scroll over it.also how do i add photorealistic people to the image and where can i get these from. your ideas/comments would be much appreciated
      thanks
      chris
        sepo
        I would say: glass reflections and some bumps. On postprocessing you need a bit more contrast as image is little flat.
        edit: also it looks unnatural to have light and light sconces under the canopy on a such bright day
          chrischeal69
          what do you mean by bumps + do i add more reflection just upping the reflection number in the materials editor.
            sepo
            yes but you need to reflect something so I would say maybe an image behind the camera or bake reflections in glass. Bumps=bump mapping.That would give more depth to your cladding. I use Kerky not that often so hopefully somebody will chime in with more detailed instructions on how to.
            • jenujacobJ Offline
              jenujacob
              to make glass in KT... rename ur glass material in SU as TG_xxxx.. (where xxxxxx can be anything)
              when exported KT will automatically apply the thin glass shader to the above mentioned material.. adjust the transparency if needed in KT...
