    Ruby dev environment
    10 Posts 6 Posters 4.5k Views 6 Watching
    • A
      a4chitect
      my current workflow is:
      1.writing scripts in notepad++ (pretty good syntax highlighting, but haven't found any autocomplete functionality)
      2.each change of a script has to be saved
      3.after each change I have to load the script in sketchup with the script_loader.rb
      4.run the script with open ruby console to debug
      I have come across sketchup bridge by tbd, but I would like to here from you about your workflow and possible enhancements to mine.
      • Didier BurD
        Didier Bur
        I use RDE (good and custom highlighting) along with the Ruby toolbar by J.Foltz.
        Clicking on an icon to load a rb is much faster than using the Plugins/Load script menu.
        I also made myself an icon to test each new function.
        DB
        • A
          a4chitect
          nice tip didier, thanks. btw is it possible to have the ruby console accept entire paragraphs of script instead of only a line?
          • tbdT
            tbd
            I use RDE/Bridge combo with ALT+F1 to send what I wrote in RDE to SU.
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
            • Didier BurD
              Didier Bur
              Unfortunately no.
              DB
              • G
                GreyHead
                I guess the Aptana Eclipse PlugIn for RadRails would also work well. It includes what appears to be a good ruby editor and debugger (you can ignore the RadRails bits after installation). The community version is still free and more than adequate as a code editor.
                I use the Zend Studio Neon which is a PHP equivalent and, despite some shortcomings, prefer it to the full Zend studio.
                Bob
                • J
                  Jim
                  Maybe WebConsole. I use it sometimes for testing longer snippets.
                  Error 404 (Not Found)!!1
                  (sketchuptips.blogspot.com)
                  • J
                    Jim
                    @didier bur said:
                    Didier, Thanks for the recommendation. The latest version can always be had here
                    • A
                      a4chitect
                      yeah thanks! how comes I forgot I had this downloaded 😄 thanks jim
                      • R
                        radhikari
                        I find Notepad++ easy and nice. Here please find some files which makes ruby editing in Notepad++ easier. The ruby.xml goes to plugins/API folder and the stylers.xml goes into C:\Documents And Settings(users)\application support\notepad++ (or something like that... I wish I had windows right now). Further instructions in the notepad++ website. ruby.xml makes the autocompletion easy.
                        Happy scripting!!!
                        Notepad++ autoCompletion for ruby and Sketchup
