    Help Please!
    2 Posts 2 Posters 1.9k Views 2 Watching
      mauritsboreel
      First of all i really like sketchy physics. I tried all the new functions in the new version and its great! Im only having one problem that i also had in the previous version. I hope i can explain what i mean because my english is not that good. If i make a box for example and cut a hole through it (with push pull function) and place this on something static, If i now make a small ball and place it in the box, it falls right through it. The only solution seems to be to make the box a static mesh, But thats just not what i want. Offcourse i can make the same "box with a hole in it" from 4 independent walls but that makes it a little complex. Can somebody help me out on this one?? Thanks in advance
      Regards Maurits
        CPhillips
        @mauritsboreel said:
        Regards Maurits
        Sorry Maurits, that is just the way it works. All objects must be convex or be made of convex shapes. Static mesh is special because it never moves.
        The reason is; if non convex objects were to move it would make the whole thing much much slower.
