    My home corner
    20 Posts 10 Posters 3.2k Views 10 Watching
    • majidM
      majid
      last day my home corner was a really good subject for remodeling and render .... so i did ... and here is the result πŸ˜„
      sunset
      afternoon
      • GaieusG
        Now tell me which is the photo and which is the model+render??? πŸ˜„
        • majidM
          majid
          you r kidding , both are renders.... i.ll send u the model or the picture.
          it would be interesting 4 me if you try it 2
          try the model
          skp
          • R
            remus
            very good renders, like gai i thought one of them was a pic. Which render did you use?
            • GaieusG
              Yes I was actually kidding but really I was also uncertain a bit - take this as a compliment if you wish - the renders are so perfect that they a deceiving my eyes...
              πŸ˜„
              Thanks for the skippy - I can give a shot though I'm far not a good renderer.
              • R
                remus
                well i was convinced.
                • majidM
                  majid
                  did anyone tried another render of the model i posted?
                  • K
                    kwistenbiebel
                    I think no one dares to compete with the images you made. πŸ˜†
                    The athmosphere on both is amazing. Those curtains are alive !
                    • majidM
                      majid
                      here are the real pictiure ( last day i picked ) ... more complicated than i made... and also .... it is reality πŸ˜‰
                      • GaieusG
                        I did play with it a little bit but then I'd never post the results here... 😳
                        • majidM
                          majid
                          btw we could improve ... here by the opinions
                          • M
                            maleemk
                            Here is my try with the Fryrender. no post processing in fryrender or sketchup.
                            i want to point out one thing though is there any way we can improve the smoothness of objects like vase in this case in renderers ????. i remember this kind of option in Accurender ( in old days when i use it and 3d modelling in AutoCAD 🀒 ).
                            • david57D
                              david57
                              Nice Work, Thanks for the model.
                              • majidM
                                majid
                                nice work , well done . and as i see your vase render is smoother than what i did .which option does that smoothing?
                                • FrederikF
                                  Frederik
                                  First of all... Nice job, maleemk...!! πŸ˜‰
                                  I assume that you've used the SU2KT when you originally exported this scene, Majid, right..?? πŸ˜•
                                  If so, you should try to export it as OBJ and import it to KT, and you'll notice that the vase will be smoother... πŸ˜‰
                                  Reason for this being that SU2KT doesn't export vertex welding and smoothing surfaces will appear more angular...
                                  Cheers
                                  Kim Frederik
                                  • soloS
                                    solo
                                    I gave it a quick go, wanted to remake the vase smoother but decided against it.
                                    Used soft focus in post edit only.
                                    http://img299.imageshack.us/img299/715/scftesta1xf3.jpg
                                    http://www.solos-art.com
                                    • FrederikF
                                      Frederik
                                      That's - as always - very impressive, Pete..!! 😲 πŸ˜„
                                      What render app. did you use for this..??
                                      Cheers
                                      Kim Frederik
                                      • majidM
                                        majid
                                        majid:
                                        thanx , good advise . i'll try the way πŸ˜„
                                        • R
                                          richcat
                                          Its such a nice scene I thought I would give it a go. I do like my corners.
                                          http://nxt.accurender.com/photos/sketchup/images/2416/original.aspx
                                          PS Thanks Pete for the Sponza skp. I'm now starting to have some fun with renderings with IRender nxt beta 😍
                                          • N
                                            notareal
                                            majid:
                                            Also with .obj export you can do loop subdivision in KT! Helps a lot with low poly SU models. I just wish that vertex welding issue would be fixed soon in SU2KT.
