    Late Christmas Upgrade
    5 Posts 3 Posters 606 Views 3 Watching
      danny
      Will, I think I was a good boy last year cuase Santa got me some new upgrades...
      SPECS:
      MB: ASUS MAXIMUS FORMULA SE V1.03
      CPU: INTEL C2D E6850 G0 @ 3.8GHZ 475x8 1.4v
      RAM: Corsair XMS2 DOMINATOR 8500C5D 4x1GB 5-5-5-15-2T 2.14v
      GPU: ATI Radeon HD 2900XT @ 850MHz core/1Gb 2150Mhz DDR4
      HD-1: Seagate Barracuda 7200.10 ST3250410AS 250GB
      HD-2: Seagate Barracuda 7200.10 ST3300622AS 300GB
      HD-3: Seagate Barracuda 7200.10 ST3750640AS 750GB
      DVD: PLEXTOR PX-716AL Dual Layer
      SOUND CARD: Creative Sound Blaster X-Fi XtremeMusic
      PSU: PC Power and Cooling ULTRA-QUIET, SILENCER 750
      CASE: SilverStone Black Temjin SST-TJ03 Aluminum Case
      FAN CONTROL: Sunbeam 4 Channel Rheobus
      OS: Windows XP PRO SP2/XP PRO 64 (Loading soon Dual Boot)
      COOLING:
      CPU BLOCK: FuZion Extreme Performance CPU Water Block
      GPU BLOCK: DangerDen DD-29XT Water Block
      RAD: ThermoChill PA120.2 2x120mm High Performance Radiator
      FAN: Delta EFB1212SHE 120x38mm Triple Blade High Speed Fans@141.96 CFM x2
      TUBES: Tygon R3400 1/2in.ID 3/4in.OD Black Laboratory Tubing
      PUMP: Swiftech MCP355 w/Custom Black Delrin DDC Pump Top
      COOLANT: Fluid XP+ Ultra Non-Conductive
      MOSFET: Thermalright HR-09U Type 2 Mosfet Cooler x2
      NB: Thermalright HR-05 Fanless Chipset Cooler w/ Evercool 70x15mm Aluminum Fans
      SB: Thermalright HR-05 Fanless Chipset Cooler w/ Evercool 70x15mm Aluminum Fans
      With this setup I was able to do the "Crowd Test" all the way to Scene 10 pretty smooth and zooming in and rotating still left everyone in color and happy, as I clicked on Scene 11 I was ready for the worst but then rotated then zoomed in and rotated again with a slight delay and didn't see any wire frames I said to myself...COOOOL!!! On my older rig I was seeing wire frame at Scene 7 or 8, so I'm happy so far. I also have "Use hardware acceleration" ON. Running the GPU on Catalyst 7.12 and to reduce the jaggy eadges (which I posted on Asher77 thread) in CCC (Catalyst Control Center)I have these settings...
      Standard Settings: "Use custom settings" box is Checked
      Anti-Aliasing: "Level" set to 4X, "Filter" select Box
      Anisotropic Filtering: "Pre-pixel sample" set to 8X
      Catalyst A.I.: On the slider set to Advance
      Mipmap Detail Level: On the slider set to Quality
      If you have an ATI card try these setting the outcome atleast for me is very smooth lines throughout the model.
      Comments very welcome. πŸ˜‰
        tomsdesk
        Danny, cool! Santa's a good ol'boy, huh!?! How do you stack up to the "turn on shadows" test? (My numbers with an nvidia FX1700 are here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=72&t=3883&p=23398#p23398 )
        2.5D Trees & Shrubs!
          danny
          Hi Tom,
          Well that does put the brakes on now....huh!!!!
          SU6
          Scene 6 - 2.5 sec.
          Scene 7 - 3.5 sec.
          Scene 8 - 5 sec. (your 1.5 sec. faster at 3.5 sec.)
          Scene 9 - 9 sec. (your 0.5 sec. faster at 8.5 sec.)
          Scene 10 - 16 sec. (even)
          Scene 11 - 18 sec. (I'm 13 sec. faster)
          No wireframe throughout the scenes. Your running a Quadro gpu, right Tom? I actually had gaming in mind when I was building this rig and you should see this rig play games...BioShock, Call of Duty 4, Unreal Toutnament III and Crysis. All on max settings except for Crysis it only let me go to High setting till I add the 1.1 patch then I'll try Very High. Details are awesome, with the light turned off and my 5.1 sound cranled up it totally draws you in the game.
          I guess I should be happy with the overall performance, SU runs a lot smoother and with the CCC setting I have above all lines a straight no jaggy lines. I think the best thing is my temps are in check because of the watercooling setup.
            remus
            a pretty sweet machine by all accounts! why dont you try running crysis and SU at the same time to really push the graphics card πŸ˜„
              tomsdesk
              Danny...cool again! I'm quite happy with the quadro, but after seeing the settings choices and realizing SU isn't really heading this way, I may have opted for the for the GeForce (though your ATI seems to be a screamer too!).
