    How Display in menu?
    2 Posts 2 Posters 396 Views 2 Watching
    • E Offline
      el.antuan
      Hi all!
      ¿How do you display the ruby scripts in the menu? ¿How can I sort the scripts?
      Some of them appears in the "Draw" column, and the others, in the "plugin" column. ¿Can I make another column "Custom", for example?
      Thanks in advance and regards 😎 :
      Antonio
      "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
      • jujuJ Offline
        juju
        Organizer script from Smustard can help you sort the scripts. IIRC there are one or two other scripts that does more-or-less the same thing, but I don't remember what they are called. I'm sure a look-see in the Ruby Script Index could help out as scripts are usually called something logical and easily recognisable if you know what function (-s) you require.
