    File > Export Menu ... Is there way to add a script there
    3 Posts 2 Posters 613 Views 2 Watching
    • JClementsJ Offline
      JClements
      I just installed the LightWave (version 6) export plugin.
      The ruby originally assigned it to the Tools Menu but I'd like to put in a more logical place for me which would File > Export.
      Is there a syntax for doing this?
      This is as far as I got:
      if !file_loaded?(FILE)
      add_separator_to_menu($exStrings.GetString("Tools"))
      UI.menu($exStrings.GetString("File")).add_item($exStrings.GetString("Export LWO [lwo_export.rb v006 Alex Young]")){ Shaxam::LwoExporter.menu_entry }
        Jim
        John,
        Unfortunately, no. You can add items to any of the top-level menus, and you can create your own sub-menus, but there is no way to add to already created sub-menus.
          JClements
          Too bad.
          Thanks for the quick reply, Jim.
          Do I assume that this has been put on "the wishlist" at one time or another?
