    Select By Layer
    1 Posts 1 Posters 530 Views 1 Watching
    • E
      ezt
      Here is a script for selecting items in a particular layer.
      #Make sure this ruby file is loaded
      ("require" will load a file only if it is not loaded yet)
      require "sketchup.rb" #Make sure this ruby file is loaded
      def select_by_layer
      # First get a list of all of the layers in the model
      model = Sketchup.active_model
      layers = model.layers
      names = layers.collect {|l| l.name}
        # Display a dialog to pick the layer to select
        prompts = ["Layer"]
        values = [names[0]]
        enums = [names.join("|")]
        results = inputbox prompts, values, enums, "Select By Layer"
        return if not results
        # Now select everything on the selected layer
        layername = results[0]
        do_select {|e| e.layer.name == layername}
      define our file name so we will know when we load it twice
      filename="selectbylayer.rb"
      #run this code the first time this script is loaded
      #If it is loaded again, file_loaded!(filename) will return true
      if !file_loaded?(filename)
      # get the SketchUp plugins menu
      plugins_menu = UI.menu("Plugins")
      # add a seperator and our function to the "plugins" menu
      if plugins_menu
      plugins_menu.add_separator
      plugins_menu.add_item("Select By Layer") { select_by_layer}
      # Let Ruby know we have loaded this file
      file_loaded(filename)
      This shows the layers in the model as a drop down list and the items selected are those in the layer chosen from the drop down list.
      What I would like is the layers to be shown in a list with checkboxes. The selected items would then be defined as all those in the layers where the boxes are ticked.
      Is this do-able? Can anyone tell me how?
      Many thanks in advance.
