    Entity.set_attribute infinite loop
    6 Posts 4 Posters 861 Views 4 Watching
      mocathe1st
      Just wondering if anyone can help me with a problem I've been struggling with all day 😞
      I'm trying to assign a unique id attribute to each face entity that is created when the plugin is running. I've set up a model observer so that every time that onElementAdded is fired it checks whether the new entity is a face and if it is it does the following:
      entity.set_attribute('test', 'id', id)
      The problem is that when this happens I start to get an infinite loop and eventually sketchup crashes. I've whittled the cause of this down to the attribute being set, this seems to create the face over and over again.
      The following is the code I've got to do this:
      def onElementAdded(entities, entity)
      	puts entity.typename
      	if entity.kind_of? Sketchup;;Face
      		if entity.get_attribute('test', 'id') == nil
      			puts "setting attribute"
      			entity.set_attribute('test', 'id', 'blah')
      In the above code I've just put 'blah' as the id to make sure that it wasn't the unique id that was causing the problem. BTW, the unique id is just a timestamp.
      Any help or suggestions would be greatly appreciated.
      • AdamBA Offline
        AdamB
        I came to conclusion the set_attribute stuff and observers really don't get along. They are, in my experience, at best very flakey when used together. I gave up setting attributes from within observers all together...quite annoying.
        I'd love to hear of any toptips to make it work though..
        Adam
          todd burch
          Unfortunately, you can't change an entity inside an observer that tells you that entity is being created. When your observer gets called, it is inside SketchUp's internal commit scope of the entity creation. Anything you change about the entity will cause a new commit scope, and that breaks things. That's my understanding of it.
          Todd
            Jim
            Adam
            I just did this by starting a timer to defer the execution of the block.
            UI.start_time(0.1) { entity.set_attribute('test', 'id', 'blah')  }
            I don't like it, but it worked.
            • AdamBA Offline
              AdamB
              Yeah, my solution was just as nasty. I add a reference to a global list and flush the list outside the observer context. Horrid.
              BTW I understand Todd's explanation wrt recursive invokation but I found I had problems if I set_attribute in an InstanceObserver too which to me is pretty unreasonable.
              Adam
                mocathe1st
                Hi Thanks for that solution, I've tried it and it works a treat.
                Its a bit hackish but it works so it'll do.
                Thanks again.
