    Render from new project
    3 Posts 2 Posters 550 Views 2 Watching
      3D view
      3D view is not a program
      hi people, thi is a 1º render in 3D view, an oficce in argentina, we make renders using SU and KT.
      Feel free to comment.
      • N
        Nick W
        Welcome to the forum 3D View (do you have a name?;)
        Nice looking render.
        You could throw some sun on this side of the building - might showcase it a bit better than having it in shadow. Having the sun come from the foreground will also match the shading of your people cutouts a little better. You could rotate some of your trees so they don't look cookie cutter right down the line - both the big ones on the left and the little ones next to the building. Could also track down a higher res sky bg for better effect - do a search on this forum or on your fav search engine, should be able to find something...
        Thanks for sharing!
        http://www.nrwiesneski.com
          3D view
          you have reason about the skie and the sun and shadow is only for te ubication if the building in the street and the requerimient of the client and my name is ricardo
