    I need help to install sketchy physics 2 like you installed
    5 Posts 3 Posters 2.5k Views 3 Watching
    • F Offline
      Feddecheese
      It was alot easier to install sketchy physics when all you had to do is
      put some things in the plugin folder. Does anyone have all the files i
      would need to put in the plugin folder if so email me an attachment with
      the whole plugin file please. Email me at james@ifeddema.com. Thank you.
      James Feddema
        Bryden
        I will sent you the files if you want.
          CPhillips
          I can create a .ZIP of the files if you want. Mind if I ask what problem you are having with the installer? I really want to make sure its as good as possible.
          James Feddema
          • F Offline
            Feddecheese
            yes if you could CPhillips. For me it is much much more convienent to install the sketchy physics 2 like you installed the first version.
            Thx,
            James
              CPhillips
              Thx,
              James
              Ill send it to you this weekend. I don't have access right now.
