    An argument of infinite proportions (pi)
    24 Posts 10 Posters 891 Views 10 Watching
      Masta Squidge
      More than that even, if you look on wiki it says more than one thing, being that its wiki and anyone can change it, but it states several billion and over one trillion places on the page.
      But more so than whether or not he is right about pi is that he is using false logic.
      He stated to me that since someone made it, that means it HAS to have an end. He treats numbers as if they are physical creations.
      If he is applying the same logic to the decimal for 1/3, then he obviously has no idea if pi ends or not, so thats not the problem, the problem is how he can assume his logic is correct when he can prove it to himself, on paper, that 1/3 never ends.
      Actually, to be honest i have no idea if you guys can follow what exactly what im trying to get across, because the connection between my brain and my typing is like running HDTV over a 400 mile long telephone line. Yet he insists that it does end based on information that is only based in his own mind, and he is unable to provide any proof except for if-then statements that have no foundation in reality.
      The biggest one being that if someone created the number, then it must end. This is obviously flawed, because number were not "created", we simply gave names to things which previously existed but had not yet been "discovered"
      Masta Squidge
      • KrisidiousK Offline
        Krisidious
        yeah I agree Bruce...
        infinity is a hard thing for people to grasp... but some things are unanswered, we never know for sure. or at least not while we ask the question. math may or may not be natural. I see it more as our description of the universe...
        from when the single cell splits 1+1=2 to π the whole universe is math... but it may have an edge? an end? that 13 dimension theory calls for multiple universes would that not mean that infinite was not so infinite after all?
        Krisidious
        By: Kristoff Rand
          Masta Squidge
          modelhead wrote:
          I'd say you are wasting your energy on this person...right or wrong.
          You show a lot of passion in your (other thread) discussion that would be better directed to your art. I am guilty of this myself from time to time.
          One other thing....I do think it is good that you are trying to understand his point of view although it seems to be a moving target. Remember the number of times that you have heard the word "impossible" in your life. I hope that you rarely pay attention to that word.
          Cheers!
          There is nothing I enjoy more than a proper debate, but since that is a rarity I will settle for giving my best to argue my side of a story, providing as much proof as I can (unlike most people who think their opinion is the end all be all).
          Only when the other person proves me wrong will I accept that fact.
          The beauty of forums is that I have time to look up my information before I make a post, that way I try to be as accurate as I can be.
          Masta Squidge
            Masta Squidge
            Sorry for the double post Embarassed
            Even if the 13 dimension theory was true (I kind of like that theory) the concept of infinity would still hold true for things like numbers, who occupy no real space physical or otherwise, and so has no bounding limits regardless of any limits the universe might have.
            Like I told that kid, you can always add one more, and in the same regard for the negative end of the number line you can always subtract one.
            I think the only limit for numbers would be the physical limit of the size of the universe not having enough room if filled with sheets of paper, stacked up and spread out in multiple stacks across the entire universe, filling every square nanometer, to write down all the numbers!
            Masta Squidge
              Masta Squidge
              Would you guys agree with this post? I just sort of figured it all out as I went along:
              Quote:
              Quote:
              Etchii wrote:
              PI is non terminating, non repeating. (I find the non repeating part hard to believe... in my head if you were patient enough to keep dividing and ended up with 10^10000000000000000000000000000000000000000000000000000000000 digits...somewhere there has to be a pattern. Even if it is a 10 billion digit sequence.)
              1/3 is non teminating, repeating.
              divide 1/3
              .33333333333333333333333333333333333333333333333333333333333333333333333 (see it will never end, just keep dividing for your entire life...enjoy a legacy of 3s)
              Quote:
              Masta Squidge wrote:
              Actually i understand your logic, there are 10,000,000,000 possible combinations of the numbers 0-9 when only using 10 places, ten digits to the power of ten. Which either you figured out or its a fluke that you said 10 billion.
              However the reason why that may be untrue, is that in order for the pattern to repeat, you would need the first 10 billion digits and the second ten billion digits to be in the same order.
              But the problem comes when dealing with 10 billion digits, as you then have 10 billion places to take into account, which pushes the number to 10,000,000,000^10, and im not willing to figure that one out, as the character limit of this post probably wouldnt touch .1% of the digits.
              What I mean is that the more places you have, the more possible combinations of 0-9 you have. When this is taken into account it is easy to see why its posisble that it will never repeat.
              Lets not forget that a pattern of ten billion digits repeated twice then has 20 billion^10 combinations.... pusching that even farther out of reach.
              Masta Squidge
                Masta Squidge
                I just re-read that and my typing is horrible when I'm on a roll.
                Masta Squidge
                  SchreiberBike
                  Nobody made Pi or 1/3, they are ratios. Perhaps if he believes that God made the universe he will believe that God made those ratios. If God did it, perhaps he will believe that the ratios have no ending when expressed as numbers.
                  SchreiberBike
                    Masta Squidge
                    Good point, in fact, I dont think I can think of any response for that.
                    But I told him half a dozen times that nobody "made" the numbers, hes just one of those thick headed kids who by a strange coincidence is also a conspiracy theorist.
                    Somehow he managed to bring a discussion about mathematics around to a discussion of what I believe happened on 9/11, the went totally off explaining how the government did it.
                    Sorry, but I personally don't care how it happened, what I care about was the fact that it happened at all, and shouldn't have. But that's got nothing to do with this now does it!
                    I love the interwebz, its where everyone has a voice, even the people who act so dumb that logically (based on their portrayed intelligence) they shouldn't be capable of understanding how to type.
                    Masta Squidge
                      SchreiberBike
                      There's a really good joke about the wisdom of arguing on the Internet, but it is not PC at all, so I won't post it.
                      I did once have a long series of respectful discussions about global warming and actually changed some people's minds. I find that pretty amazing.
                      SchreiberBike
                        Masta Squidge
                        Please by all means message this joke to me! Unless its the one about the Special Olympics of course lol, because that is all too familiar.
                        Masta Squidge
                          JuanV.Soler
                          My thinking is that pi, must in fact, end .
                          (for it must provide a shape).
                          Whilst 1/3 does not have to provide a shape.
                          it is not his work.
                          can dream.
                          JuanV.Soler
                            Masta Squidge
                            it is not his work.
                            can dream.
                            Smile
                            ooh circular reasoning (pun intended)
                            That makes sense, however there is nothing to say that a ratio cannot work properly without an end, only infinitely increasing levels of accuracy (which on its own is a paradox, because you cant do better than perfect right?)
                            I would be interested in running that by someone in the profession of calculating stupid numbers to places beyond any usable level of accuracy. Something about that statement, while it makes sense right now, doesn't exactly sit right in the back of my mind and I cant place it.
                            Anyways, I'm off to bed so I can survive work tonight, please by all means continue this because I love reading these sorts of things.
                            Masta Squidge
                              JuanV.Soler
                              Sorry, I dont get you.
                              JuanV.Soler
                              • soloS Offline
                                So who was the genius that coined the phrase "easy as pi"?
                                • soloS Offline
                                  A number isn't just something made up it's the answer to an equation. Under that definition if you take that answer to equations can sometimes be quantified as between a real & imaginary number and infinity then numbers can go on forever. Numbers can be limitless.
                                  You should tell him 2 isn't really 2 and see what he says.
                                  Pi is limitless, Pie is not... especially around guys from the south.
                                    Jackson
                                    Okay, maths is very much my weakness, but I'm confused by your stance. In the other forum you wrote:
                                    "I say they never end as pi is an irrational (which by definition never ends) and that 1/3 also never ends as it is a non terminating repeating decimal."
                                    But in your post here you state:
                                    "Now, anyone who paid attention in math class in middle school knows that he is wrong, that pi is called an irrational number for a reason, and that 1/3 does in fact end, thats why its called a repeating, terminating decimal."
                                    For the record I agree that neither number ends- especially 1/3 as a decimal. Your "opponent" ain't worth the argument if he seriously reasons that 1/3 expressed as a decimal logically ends in a 3!
                                    Jackson
                                    Jackson
                                    • 3 Offline
                                      3eighty
                                      What are you guys smoking? E Grin Pi r not Sq...Pi art round! Thumbs up
                                      3eighty
                                        Ross Macintosh
                                        someone in the profession of calculating stupid numbers...
                                        Recently it was reported that some university professor here in Canada completed a massive seven or eight year long calculation using a supercomputer. He was able to absolutely prove that a game of checkers will always end in a draw provided neither player ever makes a mistake or cheats. It is only the mistakes and cheats that swing the outcome away from a draw.
                                        Its great to see my tax dollars at work.
                                        I can't understand why anyone would think 1/3 would ever end. The repeating character of the ratio seems easy enough to comprehend as unending. I hope that university professor doesn't decide to tackle the 1/3 number next.
                                        Ross Macintosh
                                          Masta Squidge
                                          Jackson Barkess wrote:
                                          ...and that 1/3 does in fact end, thats why its called a repeating, terminating decimal."
                                          I believe that is what we call a typo Embarassed I believe it should read "does in fact NOT end, thats why its called a repeating, NON-terminating decimal.
                                          Yeah, I slipped, it was past my bedtime.
                                          Masta Squidge
                                            SchreiberBike
                                            Yep, that's the one.
                                            SchreiberBike
