    Exterior : vizdepot model [update page 3]
    54 Posts 9 Posters 12.2k Views 9 Watching
      kwistenbiebel
      Thanks.
      @Alexander: You are right. It's not an easy app to control.
      Same view, different time of day:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/vizdepot7t.jpg
        kwistenbiebel
        My attention went back to the car.....
        http://i140.photobucket.com/albums/r3/kwistenbiebel1/fordTsmalll.jpg
          alexander
          Boy Biebel.
          verrrryyyyyyyyyyyyy nice
            kwistenbiebel
            Thanks alexander 😄
            An interior tryout...The furniture needs to be re-arranged though
            http://i140.photobucket.com/albums/r3/kwistenbiebel1/interiorvizdepotsmall.jpg
              kwistenbiebel
              http://i140.photobucket.com/albums/r3/kwistenbiebel1/exteriorvizdepotsmall.jpg
                kwistenbiebel
                Still having fun 😄 :
                http://i140.photobucket.com/albums/r3/kwistenbiebel1/extviz1klein.jpg
                  Jackson
                  Kwist,
                  Looking amazing, that water is fantastic- it's not so much the reflection that makes it, but the refraction of the lake bed.... absolutely beautiful. How did you create the wave bump map or was the material bundled with Fry?
                  Jackson
                    kwistenbiebel
                    Hi Jackson,
                    It's a simple low-res bumpmap on the default Fry water preset material which is basically a ghost glass (AGS) I guess.
                    Here is the bump map I used (works as well with all different render engines):
                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/water01.jpg
                      Jackson
                      Thanks very much for posting that, very generous, can't wait to try this out. As a relative newbie to "standard" render progs (I'm a bit of an old hand at Vue, but it's material editor is very much self-contained including a bump map generator (which doesn't export 😠 )) one of the things I struggle with is creating and finding seamless bump maps. Obviously wood floors, tiles, bricks, etc are pretty easy to desaturate and edit in Photoshop, but I'm a bit stuck on how to produce waves, ripples, window deflection bump maps, grass, etc. Any tips re: bump maps? Sorry for picking your brains like this, but most VRay forums I've seen are predominately concerned with render settings (which perversely I find reasonably easy in VRay) and not so much with materials.
                      Thanks in advance,
                      Jackson
                        mateo soletic
                        Amazing images,thanks for sharing.
                        Concept Illustrations
                          kwistenbiebel
                          Thanks Mateo and Modelhead.
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/frogseyesmall.jpg
                            kwistenbiebel
                            Last one.....I am done with this scene.
                            Thanks for watching.
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/viz6.jpg
                              sepo
                              And I will be first of the last to comment. Amazing renders. The Fryrender really loves you, no doubt. Beautiful images.
                                kwistenbiebel
                                Thank you Sid...Your comments are always appreciated 😉
                                  alexander
                                  wonderfull..
                                  i thought i almost saw some fish swimming in the water.
                                  looks good biebel, can you show more how you did it ???
                                    kwistenbiebel
                                    Thanks Alexander.
                                    That's a difficult question to answer.
                                    Basically I use Fryrender in following steps:
                                    • open the Fry toolbar
                                    • select the SU material (in SU material browser) and click on the 'paint bucket' button of Fry toolbar to start editing the material...From now on a corresponding Fry material is created.
                                    • push the 'A' button (fry toolbar) and click on the viewport to set the cameras focus point.
                                    • push the 'environment' button (fry toolbar) to setup the sky and sun. Beware that the sun does not match the SU sun so you need to experiment.
                                    • push the 'camera' button (the left one) to setup your camera settings. For exteriors I mostly use following settings: iso 200, shutterspeed 1/250, fstop 12
                                    • push 'render settings' to setup the image width/height
                                    • 'export as 3d' in file menu to render. Most of the time I uncheck 'export all cameras' as it often causes a crash. See to it that 'export all geometry' is checked.
                                    About the water: there are 2 planes: 1 water plane which is basically a (ghost) glass material with a water bump applied and 1 surface below that (app. 50 cm) containg a moss texture I downloaded from http://www.cgtextures.com.
                                    Cheers,
                                    Kwistenbiebel
                                    • N Offline
                                      nomeradona
                                      biebel, i notice you render using fryrender. what was your workflow from skp file to fryrender.
                                        Jackson
                                        Nomeradona,
                                        In answer to your question, read the post above yours. :ewink:
                                        Jackson
                                        • N Offline
                                          nomeradona
                                          thnaks jackson, the above is talking about the how the material and sun has been set up inside the fryrender already. my quick question if kwisten imported the file, open an su file or what. basically from Skp file going to fry.
                                            kwistenbiebel
                                            Hi Nomer,
                                            Fryrender works completely within Sketchup (like Podium and Vray).
                                            After all the materials and light are set , you choose 'export as 3d model' in the file menu and the rendering will start automatically (= a new Fry window will open and starts the rendering).
                                            Cheers,
                                            Kwistenbiebel
                                            • 2 / 3
