    Comparing Max & KT
    17 Posts 6 Posters 1.9k Views 6 Watching
    • majidM Offline
      majid
      here is the same sobject rendered whit Max and K. k takes more time but good result
      max3
      max
      kt ,
      • majidM Offline
        majid
        does anyone knows what is better setting to export best to max , and how could reach smoot result ( for glass here )... and the best render setting (max & K )???
        thanx
        • majidM Offline
          majid
          k has some problems Huge dimentions r not displayed good ( and also very small sizes) ....how to fix it
          • jenujacobJ Offline
            jenujacob
            majid,
            i suppose u have used scanline render option for 3dMax?? KT uses a different apprach from the 3dmax scanline render.. it takes into account GI (global illumination) if u were to use Vray or Mray for max the results would be similar to what see in KT.
            i dont know much bout importing to max but for KT i suggest using Su2KT (which i am sure u are using! 😳 )
            the problem u mentioned about KT not showing large objects or very small objects is an issue of the Open GL. if u are using su2kt and render from the cam positions it should be fine.. only thing is the viewer inside KT would be all messed up..
            another small thing.. if rendering HUUUUGE scenes i would suggest using Unbiased render methods such as PPT or BPT or MLT. thats becoz PM+FG has certain limitations for rendering huuuge meshes..
            regards,
            JJ
            • majidM Offline
              majid
              thanx .
              and what r those abbr.? pm (photon map ) bpm?...
                jenujacob
                PM = photon mapping,
                PPT = path tracing (progressive)
                BPT = bidirectional path tracing
                MLT = Metropolis Light Trasfer
                these are the different render presets available in KT! the best of both biased and unbiased worlds! πŸ˜‰ 😎
                  Roger
                  Are these renders all done from the same file without adjustment to the lighting after exporting from SU? KT looks by far the best, but I find it hard to believe it is the same lighting scheme. However my only experience is with KT for automated renders.
                  http://www.azcreative.com
                  • majidM Offline
                    majid
                    the ligh emiter KT r faces , but Max .point lights
                    • majidM Offline
                      majid
                      just ...
                      • majidM Offline
                        majid
                        here is the reality ( camera), kt is more real!!!
                        • soloS Offline
                          majid,
                          How experianced are you with 3D max?
                          • majidM Offline
                            majid
                            here is kt again
                            • majidM Offline
                              majid
                              i dont know max 2 much just rendering ( and somtimes lighting)
                              • StinkieS Offline
                                Stinkie
                                I'm neither a Max or a KT user, but I feel the need to add something nonetheless. I'm like that. Ask me mum.
                                Here it is: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=5666143&linkID=5572501
                                Opinion's free, but facts are sacred.
                                • majidM Offline
                                  majid
                                  here is my last render using su+kt , retouched @ ps
                                  • F Offline
                                    Fletch
                                    for some, put a chisel and hammer in their hand and you will get "David", others, you will get dust.
                                    my point?
                                    One may not judge any render engine by seeing another user's first attempts. They may only judge the user's attempts.
                                    Fletch
                                    Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                    • majidM Offline
                                      majid
                                      really good and true poit u have . btw kt is more easy to use and good result 4 me (and i guess other who r new in 3d rendering!) . thanx again Fletch
