🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Problem with rotation in a Ruby script
6 Posts 3 Posters 862 Views 3 Watching
    Ricardo
    Hi everybody,
    I'm new in Ruby but have some experience in other programming languages. At the moment I'm working in a script to create planar sundials to simulate them in SU before making the final device. To do this I need to rotate the style by a certain angle (geographic latitude) that is passed by the user to the script. If I use the variable "incl" in the script nothing happens, but if the variable is replaced by a number (e.g. 45) it works perfectly.
    Does anyone know what can be wrong? I searched in many different sites and foruns, but wasn't able to make it work.
    def teste
      prompts = ["Inclination"]
      values = [0.0]
      results = inputbox prompts, values, "Specs"
      return if not results
      incl = results
      model = Sketchup.active_model
      model.start_operation "Draw"
      entities = model.active_entities
      group = entities.add_group
      entities = group.entities
      circle = entities.add_circle([0,0,0], Z_AXIS, 8.mm, 24)
      cyl_base = entities.add_face(circle)
      cyl_base.pushpull -100
      entities.transform_entities(Geom;;Transformation.rotation([0,0,0],[1,0,0],incl.degrees),group)
    #entities.transform_entities(Geom;;Transformation.rotation([0,0,0],[1,0,0],45.degrees),group)
      model.commit_operation
    if( not file_loaded?("teste.rb") )
      add_separator_to_menu("Draw")
      draw_menu = UI.menu("Draw")
      teste_menu = draw_menu.add_item("teste") { teste }
    file_loaded("teste.rb")
    Thanks for any tip.
    Best regards,
    Ricardo
      Jim
      inputbox returns an Array, so incl is an Array and there is no .degrees method for Array.
      incl = results[0]
      Smack - the sound of your palm hitting your forehead.
        Ricardo
        Jim,
        Thanks for the fast response. I made the change and it works properly, but I'm still confused because the variable "incl" is displayed properly using the UI.messagebox without using the index of the array. The same happens with the variable "factor". If I make the product of "incl" and "factor" and use the result in the rotattion command it works fine as well (see code). Does this mean that only in certain methods (eg. rotation) the index of the matrix must be used?
        def teste
          prompts = ["Inclination", "Factor"]
          values = [0.0, 0.0]
          incl, factor = results
          UI.messagebox(incl.to_s)
          x = incl * 2
          UI.messagebox(x.to_s)
          model.start_operation "Create Cylinder"
          circle = entities.add_circle([0,0,0], Z_AXIS, 2.mm, 24)
          cyl_base.pushpull -1000.mm
          entities.transform_entities(Geom;;Transformation.rotation([0,0,0],[1,0,0],x.degrees),group)
        Thank you,
        Ricardo
          Didier Bur
          Writing
          does the same as that:
          incl = results[0]
          factor = results[1]
          so you can use "results" as an array and incl and factor as strings
          Hope this helps,
          DB
            Jim
            Didier is correct, incl and factor are no longer arrays.
              Ricardo
              Jim and Didier,
              Thanks for the help.
              BR,
              Ricardo
