    Web Dialog - how to
    16 Posts 3 Posters 3.1k Views 3 Watching
    • T
      todd burch
      Are you sure you are building the filename properly?
      "What" does not work?
      • T
        todd burch
        Nevermind. Put the dialog.execute_script in a callback.
        • PixeroP
          Pixero
          This is what I've tried with this time. Still not working though...
          In ruby script:
          def activate
          	dialog = UI;;WebDialog.new("jsTest", true,"JS Test", 320, 160, 600, 60, true)
              	fn= File.dirname(__FILE__)+'/jsTest.html'
              	dialog.set_file fn
          	dialog.show {}
          	posX = "1"
          	dialog.add_action_callback("setup") {|d,p|
          		dialog.execute_script("document.getElementById('posX').value='#{posX}'")
              end # activate
          In html file:
          	<script type="text/javascript">
                     function setup(id,value)
                        window.location = 'skp;setup@'+document.getElementById('posX').value;
                 </script>
          • PixeroP
            Pixero
            Bump.
            Can you see whats wrong with my code?
            • T
              todd burch
              Holy Cow!! What's wrong???? I don't think you've ever told us anything more than "it does not work".
              We can't keep (well, I'm not going to keep) guessing at what you might have and might not have that you are not showing us or telling us!
              There is HTML, javascript and ruby code that you are holding very close to yourself. Any of it might not be coded right.
              Todd
              • PixeroP
                Pixero
                Sorry, I didnt mean to be secret about it.
                It´s just that for now it´s just a (non functioning) test how to get a value from sketchup to a webdialog as default value. If I just can get some help getting this working I'll be sure to post the script I'm working on. 💚
                404 Not Found
                (www.sketchucation.com)
                  Jim
                  For starters, you never call the javascript setup function, which in turn never calls the "setup" callback in the ruby.
                  Can I ask why you are using the Tool interface for the WebDialog? I never would have thought to use it, although it does work.
                  • PixeroP
                    Pixero
                    First of all, thanks for your help.
                    I'm crawling in the dirt here and it feels like you're teasing me with small bits that I can't quite get the grips on. 😉
                    I'm just a total noob when it comes to javascript and the script I´m working on need default values from SketchUp. Please give me an example so that (even) I can understand how to get it working. 😳
                    I've looked at the few webdialog based script I've found but havent seen any that gets their default value from sketchup. They all have "onClick" and other user activated functions.
                    Why a tool? Maybe it isnt necessary but later on I'm gonna need to save a value so that it will be remembered when using the script again. I dont know if that is something that can be done without the "suspend tool"?
                      Jim
                      Short answer, add this to the html file, right before the </body> tag:
                      <script>
                      setup(0,0)
                      </script>
                      Have a look at the totd.rb file in the Tools directory. It's a good example of a WebDialog.
                      Here's my re-write. Saving values between sessions can be done using Sketchup.write_default and Sketchup.read_default.
                      require "sketchup.rb"
                      #class JS_Test
                      # Inherit from the WebDialog. There's no need to use a Tool/
                      class JS_Test < UI;;WebDialog
                        #def activate # activate is a method of the Tool class.
                        def initialize
                          # dialog = UI;;WebDialog.new("test", true,"test", 320, 160, 1100, 60, true)
                          # super called the parant class "new"
                          super "test", true,"test", 320, 160, 1100, 60, true
                          fn= File.dirname(__FILE__)+'/test.html'
                          #dialog.set_file fn
                          set_file fn
                          #dialog.show {} #show it
                          show {} #show it
                          posX = "1"
                          #dialog.add_action_callback("setup") {|d,p|
                          add_action_callback("setup") { |d, p|
                            d.execute_script("document.getElementById('posX').value='#{posX}'")
                          #end # activate
                        end # initialize
                      end #class jsTest
                      if(not file_loaded?("test.rb"))
                        plugins_menu = UI.menu("Plugins")
                        #plugins_menu.add_item("test") { Sketchup.active_model.select_tool JS_Test.new }
                        plugins_menu.add_item("test") { JS_Test.new }
                        file_loaded("test.rb")
                      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                      <html xmlns="http://www.w3.org/1999/xhtml">
                         <head>
                            <meta http-equiv="content-type" content="text/html;charset=utf-8" />
                            <meta name="test" content="test" />
                            <title>test</title>
                            <script>
                            </script>
                         </head>
                         <body bgcolor="#e0dfe3">
                            <input type="text" size="8" id="posX" value="0"></div>
                         <script>setup();</script>
                      </body>
                      </html>
                      404 Not Found
                      • PixeroP
                        Pixero
                        Thanks Jim and Todd. Really appreciated.
                        Finally back on track... 😄
                        Don't worry, I'll probably be back with more stupid questions... 😉
