π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
SU Selection Object
I have been playing around with this interface some some and found something that I consider to be a bit odd. The selection object stores the selected items in a way that seems to be unrelated to the order in which they were selected. It is just one of those "this is not right" thoughts....
You are correct. You can count on the order of selected items to be random.
Todd
I am not so sure that it is random....I just removed item [0] of a 13 item set. Then, I added that particular edge back to the set...it went back in the orginal index position of [0]!
